-   -   Should I bypass the oil cooler??? (https://www.offshoreonly.com/forums/general-q/81509-should-i-bypass-oil-cooler.html)
Grog 06-17-2004 01:52 PM
1999 502 MPI
Whipplecharged
no water t-stat
stock oil cooler
Since I installed the Whipplecharger, I have been having problems with what I think may be condensation in my oil. To prove this, I installed a Gaffrig oil temp gauge at my remote oil filter (before the cooler). The best I can get after a hard run is 210°. Most of the time, it runs at around 165°. It takes forever to warm up and when I am idling in a no-wake, it drops to around 140°. I think this is too cold for oil!!!
Since I don't run a water thermostat with the Whipple, the water temperature only gets to 105° even in the hot Arizona climate.
Here is my question: Would it be a smart idea to bypass the oil cooler to see if I can get the temps up to a more normal operating range? It would be totally experimental at first and since I can monitor the oil temperature as I go, I can back off of the throttle if the oil gets too hot....say above 260°. It would also be interesting to see just how much the oil cooler affects oil temperature.
What do you guys think?????
Fountain38SC 06-17-2004 02:26 PM
Re: Should I bypass the oil cooler???
I'd call Dustin before I did anything to it.
robyw1 06-17-2004 02:34 PM
is there a reason you don't run a T-Stat? You should run at least a 140 or condensation will build up in your engines oil at a rapid pace. As long as the engine coolant runs at least 140 the oil cooler if integrated should warm the oil to the proper temperature. You're not really going to hurt it being this cool but it will never get warm enough to burn off condensation in the oil. You would have to change the oil very and I mean very often.
Roby
Grog 06-17-2004 02:40 PM
Roby -
Whipple is very specific about removing the t-stat on a supercharged motor to allow lots of water flow.
Krumbsnatcher 06-17-2004 03:27 PM
2 Attachment(s)
Originally Posted by Grog
1999 502 MPI
Whipplecharged
no water t-stat
stock oil cooler
Grog the way I see it the whipple is going to create a lot of heat when you are running her hard so they recommend you get as much water passing through the block, hence the removal of the T-Stat. Someone on this board should be able to give a better reason for the T-stat.
Now the fact that you have low oil temps is because you are constantly running cool water through your system. You need a Thermostatically controlled oil cooler to heat your oil when you are not running her hard. The stock merc is good for a stock motor but you do not have a stock motor. Here are a few picks of mine. I use the dual cooler one for my hydraulic steering return line.
Grog 06-17-2004 06:40 PM
Krumbsnatcher -
Would you send the images to [email protected]?
Thanks!!
PatriYacht 06-17-2004 09:08 PM
Permacool thermostat is only about 30.00 from Summit. Unfortunatly the plumbing costs alot more. It's pretty simple. Just follow the directions.
Gary Anderson 06-18-2004 08:49 AM
Run 1) a thermostat, 2) a restrictor in place of the thermostat, or 3) an oil thermostat. Dont remove the oil cooler.
Gary
