Livorsi Tach Problem
I have twin 502 MPI & recently put two new Livorsi tachs. They read almost identical up to 4000 rpm after that the port tach flutters & bounces between 4000 - 4500 & the SB reads fine . Engines seem to run fine no miss what-so-ever. I swapped the two tachs the other day to see if I had a bad tach but same problem. any ideas?? bad ground ? I checked seems fine any ideas?? thanks,
Re: Livorsi Tach Problem
I swapped the SB tach for the Port, does the same thing - SB side has a problem somewhere??
ttt everyone must be out boating??
| All times are GMT -5. The time now is 12:11 PM. |
