Need Jetting Advice >
Need Jetting Advice
Need Jetting Advice
Old 06-28-2004 | 03:14 PM
KNOT-RIGHT's Avatar
Default Re: Need Jetting Advice
like LLyod Said
The most important thing overlooked in adding blowers is fuel.
You are wasting your time jetting until you get proper fuel to the carb.
I just went through the similar situation. I replaced my tubes with 1/2
inch. I also had to run returns and bigger vents. If I remove the fuel feeds to the carbs I fill a 1 gallon container in less then 13 seconds. The fact that your only running one carb actually requires more then someone running two carbs per engine. I have fuel pressure gauges on dash and didnt see them
drop either. But it was still starving for fuel.
Good luck
Remember lean is mean.
Gerry
KNOT-RIGHT is offline
Old 06-28-2004 | 03:21 PM
Krumbsnatcher's Avatar
Good luck
Gerry
I think you guys have convinced me that it is a fuel supply problem. I can easily get to my fuel tank and vent tube. What precautions must I make prior to removing and replacing the tube. Is there any special tube i need to get other than 1/2 tube.
What steps should i take, I just towed the boat 300 miles from my lake house and it still has 3/4 tank. The gauge was showing empty or barely moving so before we tested we dropped another 25 gallons, then the damn gauge popped back to life and i was at full tank again.
I would like to tackle this project prior to leaving, any advice.
Thanks again.
Krumbsnatcher is offline
Old 06-28-2004 | 03:22 PM
Originally Posted by Pure Energy
My fuel pressure did not drop! It was very frustrating to diagnose.
I was afraid you were going to say that!
Old 06-28-2004 | 03:23 PM
I have the standard 3/8 npt 90 degree brass fitting coming out of the fuel tank. I will post some pics tommorow.
Old 06-28-2004 | 04:33 PM
My fuel pressure did not show a drop on the gage either.
lloyd is offline
Old 06-28-2004 | 04:50 PM
KNOT-RIGHT's Avatar
This is what I ended up doing. I have 3/8npt female welded bungs in the tank.The restrictive 3/8 alumminum tubes slid into these with a 3/8 brass
90 on the top. I removed and tossed these tubes and brass 90,s. I went to the local hobby shop and puchased 15/32 thinwall brass tubes.
these are 1/32 less then 1/2 inch id. They fit perfecly in a double male 3/8
npt nipple. I "mean perfect" I measured the correct depth off old tubes.
allowing for the threads on the nipple. I cut a 45 degree on the bottom of the new brass tubes and solderd the nipple on top. Dropped them in the 3/8npt tank bungs. Threaded a non restrictive brass elbow on the top then went with aeromotive # 10 pipe adapters to the # 10 hose. then to wix
high flow filter heads 1/2 npt.
This procedure allowed me to increase the pickup tubes without any cutting or drilling.
If you have the same on your tank dont hesitate to call me ill walk you through it.
Hope this helps
Gerry
401-255-5242
Old 06-29-2004 | 12:46 PM
Hope this helps
Gerry
401-255-5242
I might just be doing that, I am on the west coast what timezone are you located?
Anyway here are some pics as promissed of my fuel system starting at the tank.
Attached Thumbnails Need Jetting Advice-img_1.jpg   Need Jetting Advice-img_2.jpg   Need Jetting Advice-img_3.jpg
Old 06-29-2004 | 12:52 PM
img4 shows the fuel separator after the fuel pump, and 5 shows you the level of the fuel line to the pump if you look real close.
Thanks guys.
Hey Blownhavasu, you ready to work tonight?
Attached Thumbnails Need Jetting Advice-img_4.jpg   Need Jetting Advice-img_5.jpg
Old 06-29-2004 | 12:56 PM
This is the baby that is causing me and BlownHavasu so much greif and the sad part is that we have our wifes with us on the weekends so they want to play and we want to dial in this engine!
Thanks again OSO brothers.
Old 06-29-2004 | 01:16 PM
KNOT-RIGHT's Avatar
Im on the east coast its 2:00 pm here Are those 3/8 npt threaded in tank???
