140 merc points system ignition question >
Old 06-24-2004 | 10:01 AM
later's Avatar
Default 140 merc points system ignition question
a freind has a 85'ish run-about with a 140 merc I/O, does anyone know what the voltage should be on the + (plus) side of the coil while it is running.
thanks
later
later is offline
Old 06-24-2004 | 02:39 PM
jdwlac
Default Re: 140 merc points system ignition question
If A Resistor Is Used, Should Be Around 7 Volts
Old 06-24-2004 | 09:30 PM
I don't believe that is an external resistor system so you should see 12+ volts when running. --- jp
jpclear is offline
glassdave
14
01-04-2007 08:40 PM
fund razor
15
12-22-2004 08:27 AM
tmthunder
4
09-12-2004 08:33 PM
26sonic
3
03-02-2003 07:06 AM
turbo2256
2
06-19-2002 11:33 AM
