Oil Line Size >
Oil Line Size
Oil Line Size
Old 06-25-2004 | 07:35 AM
JON242
Default Oil Line Size
I currently have #10 (about 5/8") running to my remoter filter. The fitting size for the Mercruiser oil cooler I'm installing is #8 (about 1/2"). Is this smaller line size OK?
Old 06-25-2004 | 07:40 AM
Official OSO boat whore
Default Re: Oil Line Size
If you are using AN line, then there are #10 to 1/2" adapters available. That's what I'd use.
Cord is offline
Old 06-25-2004 | 08:41 AM
Monty's Avatar
I've always used -12 for engine oil, -10 for tranny fluid, and -08 for fuel. I wouldn't go below a -10 on motor oil. I don't know if a -08 would actually limit flow volume, I'm sure some Engineering types can recall the formula to figure it out though.
Monty is offline
Old 06-25-2004 | 10:01 AM
JON242
Weird thing is I'm using a oil cooler off of a 454 mag and it has #8 inverted flare fittings built into the cooler so I'm thinking that's OK. I'm using this on a 400HP small block that I haven't had a cooler on in the past but I don't want to choke off the oil supply.
Old 06-25-2004 | 10:21 AM
PatriYacht's Avatar
Use #10 lines with 1/2npt fittings on your oil cooler and engine ports. The fittings are common and have a much larger i.d. than fittings for #8 lines.
PatriYacht is offline
Old 06-25-2004 | 11:36 AM
JON242
I can't use 1/2" fittings on the oil cooler. It is threaded for #8 fittings. I guess this is OK since it is off of a big block mercruiser but I want to make sure. Is anyone running #8 lines to there oil cooler?
Old 06-25-2004 | 04:06 PM
PatriYacht's Avatar
Strange, my 454 mag coolers had 1/2 npt threads. The system was plumbed completely with #8 lines and fittings but I don't think that's enough for a big inch engine or a supercharged application. You lose a lot of pressure going through 14 feet of hose, fittings, oil cooler, remote oil filter, oil thermostat.
Old 06-25-2004 | 04:20 PM
Krumbsnatcher's Avatar
I use a -10 with 1/npt fittings on my cooler and remote filter.
Krumbsnatcher is offline
Old 06-25-2004 | 04:33 PM
Strip Poker 388's Avatar
Rob
I used 12 you may get away with 8
Strip Poker 388 is offline
Old 06-25-2004 | 11:57 PM
robyw1's Avatar
No stay with the 10s don't step down. It is possible for the filter bypass to open up when the engine is cold if the restriction is too great.
Roby
robyw1 is offline
Cold Sweat
3
10-16-2008 10:24 AM
liquidlounge
6
10-09-2008 07:18 PM
Sneaky Fast
03-19-2008 08:42 PM
Outdrive1
74
06-22-2007 08:28 AM
jdub
5
05-10-2007 08:48 PM
