Fuel Pressure Drop >
Fuel Pressure Drop
Fuel Pressure Drop
Old 06-27-2004 | 09:50 AM
Default Fuel Pressure Drop
Last week I put the boat away with 8 pounds of fuel pressure. Started her up this weekend to find 4.5-5.0 pounds of pressure. Checked gauges and senders. Looked in the carb after shutting down and did not find any fuel dripping or wettness. Any ideas?
thanks
shawn
shawn is offline
Old 06-28-2004 | 01:16 AM
RedDog382's Avatar
Default Re: Fuel Pressure Drop
How old is your fuel filter? I noticed a drop in my fuel pressure at higher rpm's. Thought it might be a fuel pump, regulator, or bad guage, but a new filter solved the problem.
RedDog382 is offline
Old 06-28-2004 | 06:27 AM
GLH's Avatar
GLH
Might be fuel pump diaphragm done.
Don''t run with less than your usual pressure if you have a blower even a pound less cost me some $.
GLH is offline
Old 06-28-2004 | 12:40 PM
Krumbsnatcher's Avatar
I bet it is your filter you sucked up some grime from the tank. Change it you should be fine. You do not want to mess with a lean condition as GLH stated it will cost you surely.
I used to have the same problem, I finally removed my inline fuel filter prior to going to the pump. I figure a pump is easier to replace than the damn filter every time it gets clogged.
.02
Krumbsnatcher is offline
Scarab3DMC
31
09-24-2008 07:41 PM
mjb
5
08-19-2008 08:29 AM
Matty439
17
08-06-2007 12:14 AM
razor1115
17
06-04-2007 04:16 PM
articfriends
10
09-27-2004 05:03 PM
