Help I'm in starter He!! >
Old 06-30-2004 | 05:54 AM
dyno's Avatar
Charter Member #655
Default Re: Help I'm in starter He!!
its been hell...I even took the starter off my good motor and it sounded like hell too. I could see it flexing some so I cranked on it with a 1/2 rachet and cracked the housing......damn it! now I need two... Chris what do you need for both starters? call me at your convinience.... Don 616-403-4482
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 06-30-2004 | 06:36 AM
dyno's Avatar
Charter Member #655
Sut it turns over fine...I thought the same thing at the beginning of this mess I pulled all the plugs and rolled it over right away....no problem.
dyno is offline
Old 06-30-2004 | 09:08 AM
JUSTONCE's Avatar
Remind me not to tie up next to you....automotive starter....gas fumes in bilge= BOOM!!!!!!
wisetale, big block auto starters are closed just like marine the only diff. is the silicone on the connections.
JUSTONCE is offline
Old 06-30-2004 | 09:20 AM
dyno's Avatar
Charter Member #655
For real???I've used auto starters in the past becouse I was in a pinch and a tight a$$ just ran the blower a little longer before starting....I know delco makes a marine starter that looks just like the auto one....the Merc ones are smaller gear reduction one right?
dyno is offline
Old 06-30-2004 | 09:46 AM
JUSTONCE's Avatar
pretty sure, I tried everything I could to stick with the small ,arine starter cauyse I didn't want the weight of a big starter hanging there especailly with the beating I put my boat through, but It has been fine. Not sure about the reduction but you gotta make sure you got the right # of teeth on the starter gear cause there are 2 options.
JUSTONCE is offline
Old 06-30-2004 | 10:26 AM
dyno's Avatar
Charter Member #655
so how many teeth are ther supposed to be on a marine starter? 168 on the flywheel but how many on the bendix????
dyno is offline
Old 06-30-2004 | 12:19 PM
JUSTONCE's Avatar
Gotta look, can't remember. Are you sure you have the 168 tooth flywheel? It is the more common one, mine is 168, I'll check on the bendix drive gear later.
JUSTONCE is offline
Old 06-30-2004 | 12:29 PM
dyno's Avatar
Charter Member #655
yep 168 teeth I counted them last night!
dyno is offline
Old 06-30-2004 | 12:36 PM
rookie_j
this may show my inexperience, but are'nt there left hand rotation and right hand rotation marine starters??
Old 06-30-2004 | 12:41 PM
dyno's Avatar
Charter Member #655
not for stern drives.....they are the same, in boards they might.... I'm not sure.
dyno is offline
