volvo wont crank Help
Finally got it in and aligned, hooked up harness, batteries starter grounds etc. Key up buzzer sounds two short blasts, then engine buzzer does the same, I hear the fuel pumps kick on for a couple seconds then shut off. Turn key to start and nothing. This is a volvo hp600 that was adapted to a merc Bravo setup. Is there a different neutral switch on these volvos, I have two connectors that are not used one is a two wire trim connector, the other I believe has something to do with shifting the dpx, which i am not using. need help bad i am going on vaca next week
