losing RPM's after running for a while >
Old 07-06-2004 | 09:47 AM
hawk40's Avatar
Default losing RPM's after running for a while
I'm lossing power on my port engine after running fairly hard for extended times. The RPM's start slipping off after running for about 20 minutes in the 4000 range. Just had the drive refurbished. The starboard engine runs strong the entire time. TRS drives, 454's carbed. Just bought the boat last October and never ran it hard before the drive was rebuilt. Any ideas? Is this caused by something setup wrong in the drive?
hawk40 is offline
Old 07-07-2004 | 07:51 PM
Jersey Tom's Avatar
Default Re: losing RPM's after running for a while
fuel pump going bad? Filter?
Jersey Tom is offline
Old 07-09-2004 | 12:50 PM
fo-shizzle's Avatar
one more thing to check... oil level... if too high, over time the crankshaft will have a tendacy to aerate/foam the oil which then causes additional drag on the cranksaft as well as possibly causing the lash adjusters to bleed down....
fo-shizzle is offline
Old 07-10-2004 | 12:32 PM
make sure your timing is not to high and causing detonation after warmup. Won't last long that way though so prob not it.
cooltoys61 is offline
Old 07-10-2004 | 09:28 PM
WILDTHING TAZ's Avatar
B-MAX REPAIR
check fuel flow, check fuel filter for water that will stop flow, check fuel pressure.
WILDTHING TAZ is offline
Rocko C
7
08-27-2007 12:07 PM
morgansrun
11
06-12-2007 02:26 AM
Steel Outlawed
22
05-21-2006 09:43 AM
JUSTONCE
09-12-2003 04:47 PM
