motor siezed while running,,WHY?HELP!!! >
Old 07-07-2004 | 05:37 PM
birdog's Avatar
Default Re: motor siezed while running,,WHY?HELP!!!
Originally Posted by 502procharger
i broke a drive and locked the motor, pull the drive and make sure it is the motor.
For Sure !!!.............Then...Pull plugs & try to crank
birdog is offline
Old 07-07-2004 | 07:14 PM
Infomaniac's Avatar
Cut the filter open also and look for debris.
Infomaniac is offline
Old 07-07-2004 | 08:01 PM
blue thunder's Avatar
Everytime that happens to me it is a dropped valve. The dropped valve also results in a smashed spark plug though and it sounds like all your plugs check out ok. Make sure to compare the plugs closely and look for any that are steam cleaned. Tuliped exhaust valve can suck enough water to break things internally (rods) yet due the loud exhaust make it seem like a silent failure. Of course, removing the drive and cranking is the first order of business. Tomorrow I start the assembly process on my sb engine that lost a valve two weekends ago... you are not alone
BT
blue thunder is offline
Old 07-08-2004 | 05:16 PM
mtr is out of boat,plugs out of mtr,it is locked tight. I will tear down soon while building my roller mtr. Every time it breaks it's gonna get faster!That'll show it!
cooltoys61 is offline
Old 07-08-2004 | 05:29 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
See, there is a silver lining in every cloud!
US1 Fountain is offline
Old 07-08-2004 | 08:53 PM
robyw1's Avatar
It sounds as though you have broken a crankshaft my friend. Sorry to hear it.
robyw1 is offline
Old 07-08-2004 | 09:42 PM
dlbCheckmate's Avatar
I had the same problem, running 4500 RPM's motor locked up. Reason for locking up was obvious, ( rod sticking out the side of the pan ) fiding the true cause is another story. It was a fresh rebuilt motor, this sucks !
dlbCheckmate is offline
Old 07-09-2004 | 12:18 AM
Reed Jensen's Avatar
Ihad the same problem once... starboard motor locked up at about 4500 rpm... no warning ... no alarm.... this is what I found inside.....
Attached Thumbnails motor siezed while running,,WHY?HELP!!!-rod-1-resized.jpg
Reed Jensen is offline
Old 07-09-2004 | 12:20 AM
The reason for the failure was the remotely mounted oil filter was plumbed backwards.... Here is a picture of the mechanic that did the work......
Old 07-09-2004 | 07:31 AM
i still say crank shaft!
sonic28 is offline
Rockfish71
06-01-2008 01:58 PM
sleeper_dave
6
04-13-2006 01:00 PM
Shah Mat
9
08-30-2004 09:43 AM
Reckless32
16
08-27-2004 10:29 PM
Mad Hatter
07-01-2003 07:36 AM
