What Props do I need? >
Old 07-12-2004 | 07:26 PM
jmont34
Default What Props do I need?
I have a 1986 Wellcraft Scarab III. TRS drives with about 500hp 496's. What would be the best props for this set up? Do Bravo props fit on TRS Drives?
Old 07-12-2004 | 07:29 PM
RJ1340's Avatar
Default Re: What Props do I need?
You need Houston Props 5 blade. 28 pitch.
RJ1340 is offline
Old 07-12-2004 | 07:51 PM
come on RJ, the guy is asking a SERIOUS question. Don't sell those props here.
I would contact either Throttle -Up or Houston Propeller and ask their advice.
They are advertisers here. Go to Marine Link on top of page.
Thunder32 is offline
Old 07-13-2004 | 07:26 AM
throttleup's Avatar
Yes, the Bravo 1 props will fit the TRS drive with no modifications.
Most of the boats with the TRS drives work well with the Mirage or Mirage plus. The Mirage is no longer available and has been replaced with the Mirage plus. The Bravo 1 is an option as well but you will most likely lose a couple mph on the top but pick up a couple mph in the mid range.
Matt
throttleup is offline
Old 07-13-2004 | 12:42 PM
You can find a pair of used Mirage props, since many have switched to four blades. You don't need four blades with the drive as deep as it likely is on that boat. If you have enough power, the 25 Mirage is hard to beat.
tomcat is offline
mcprodesign
06-08-2008 07:54 PM
diggster69
Prop Talk
2
02-06-2008 07:59 PM
HOTTZU98
3
05-13-2005 07:43 AM
raiseyourdrive
09-15-2004 08:23 AM
dougB
0
05-06-2003 04:16 AM
