Lost power- HP500 carb motor >
Old 07-23-2004 | 06:16 AM
bglz42's Avatar
Default Re: Lost power- HP500 carb motor
Thanks guys!!
Compression checked out on all 8 cylinders, so must be ignition or fuel. Going for full tune-up now.
Thanks!
bglz42 is offline
Old 07-23-2004 | 06:29 AM
Canada Jeff's Avatar
Compresion check doesn't tell you schit about the condition of the valve springs, lifters, any of the valve train really. It will alert you to a ring, warn valve, or head gasket problem only.
How many hours!!
Do a full service, fuel filter, and all ignition components. Not worth the risk of missing something.
Canada Jeff is offline
Old 07-23-2004 | 09:45 AM
Even with a roller missing off a lifter,
( or a weak spring)you'll get enough valve movement for
a good compression test #.
I would still pull the valve covers and
take a lookie.
I did have a coil fail this spring, but the symptoms
you describe don't match mine.
jt
JaayTeee is offline
Old 07-23-2004 | 10:36 AM
formula31's Avatar
Check timing. I had a distributor holddown bolt come loose once and the dist moved enough that the engine ran good up to 2500 and then was missing and had no power.
formula31 is offline
Old 07-23-2004 | 11:45 AM
bglz42's Avatar
How many hours!!
150 hrs.
Will check it all. Thanks!
bglz42 is offline
Old 07-23-2004 | 02:39 PM
robyw1's Avatar
You have a piece of crap stuck in the main jets. remove the fuel bowl and clean.
Roby
robyw1 is offline
Old 07-23-2004 | 02:40 PM
robyw1's Avatar
Originally Posted by BajaRunner
fuel filter?
or this
robyw1 is offline
Old 08-03-2004 | 12:37 PM
suncoastdave's Avatar
Have you checked the power valves in the carb?
suncoastdave is offline
Old 08-03-2004 | 01:01 PM
bglz- based on how you describe the problem in your original post, I'd take a hard look at the ignition timing on that engine. Aside from a clogged fuel filter/marginal mechanical fuel pump/water separator,my experience with engines that rev freely,but don't pull is that you lost advance or the timing chain has jumped. Again, based on you're words, it appears that something happened abruptly. The valve spring/lifter suggestions are also consistent with the symptoms you describe.--Lou
Lmarth is offline
Old 08-04-2004 | 06:25 AM
bglz42's Avatar
Thanks guys! It was ignition...
The owner replaced all plugs/cap/rotors and fuel filters. Runs like a champ now!
Jim
bglz42 is offline
SeaWeasel
6
05-27-2008 06:01 PM
G Man
09-10-2005 10:57 PM
Stormrider
12-17-2004 12:38 AM
jdnca1
4
11-14-2004 06:34 PM
shawn
3
07-09-2003 07:42 AM
