lookin for bolt on power ! >
Old 08-04-2004 | 07:59 AM
Hydrocruiser's Avatar
Arrow Re: lookin for bolt on power !
Originally Posted by bern's 29scarab
I have a 98 29ft scarab. tryin to find out if there are any inexpensive upgrades available for the 350 mpi's. K&N's, cold air intake's, ECU upgrades etc...its currently turning 47-4750 rpm's WOT with 23p counter rotating mirage pluses. just over 70mph on a handheld garmin. it has the cheap version of the quick n quiet (no controllable)plus it has external mufflers of some sort.
I found a big improvement for a reasonable investment by:
-Crower Corvette LT-1 grind cam/roller rockers of course/rods
-Edelbrock Performer EPS Intake Manifolds
-600 or 800 cfm Thunder series Edelborck carbs
-You can mill the heads .010 to boost compression .5 or go with new performance heads too.
Without heads expect 20% or 60 HP gains with heads 80-100 HP
Speed increase 3-5 MPH
Hydrocruiser is offline
Old 08-04-2004 | 08:55 AM
Fuelish Pleasures
Default Re: lookin for bolt on power !
Originally Posted by Slick02
Curious to see the answers to this question, I've got an 02 formula 292 with twin 350 mpi's and with 28 pitch 4blades at 4900 I'm running about 68 to 69 on a good day with half a load of fuel, and the formula is heavier than the scarab.
You guys must have different gear ratios in your outdrives.
Old 08-04-2004 | 09:05 AM
Clay Washington's Avatar
Here are some general guidelines...
It cost $1000 for each additional 1 MPH.
If you look at an internal compustion engine as a huge air pump, then you want to increase airflow both into and out of the engine. A low restriction flame arrestor and after-market manifolds will help with that. Once you get more air into the engine, you need to add more gas. This means a bigger carb or a new ECM program.
The BEST bang for your buck is to add a supercharger. I have a Whipple, and I love it!
Good luck!
Clay Washington is offline
Old 08-05-2004 | 09:36 AM
berns29scarab's Avatar
thanks for all the responses....i think the blowers will be the winter project...and my drives are 1.5's...again thanks to all
berns29scarab is offline
Old 08-05-2004 | 09:52 AM
tssteph's Avatar
Fuelish, Scarabs seem to have less of a slip percentage the Formulas do. By the way nice name.....
tssteph is offline
johnlomant
2
03-28-2008 09:27 AM
nick k
12-04-2006 07:57 PM
Panic Button
4
10-06-2004 07:13 PM
still smoking
16
09-24-2004 06:24 AM
cooltoys61
0
07-01-2004 11:54 AM
