power corrections >
power corrections
power corrections
Old 07-26-2004 | 08:46 PM
LarryD
Default power corrections
I was wondering if anyone knew the formulas for correcting power for atmospheric conditions i.e. altitude, barametric preasure . relative humidity etc
Old 07-27-2004 | 06:30 AM
rmbuilder's Avatar
MarineKinetics
Default Re: power corrections
LarryD,
The two most widely used in the performance industry Are SAE & STP
· SAE (Society of Automotive Engineers), USA. Power is corrected to reference conditions of 29.23 InHg (99 kPa) of dry air and 77 F (25°C). This SAE standard requires a correction for friction torque. Friction torque can be determined by measurements on special motoring dynamometers (which is only practical in research environments) or can be estimated. When estimates must be used, the SAE standard uses a default Mechanical Efficiency (ME) value of 85%. This is approximately correct at peak torque but not at other engine operating speeds. Some dynamometer systems use the SAE correction factor for atmospheric conditions but do not take mechanical efficiency into consideration at all (i.e. they assume a ME of 100%).
· STD or STP. Another power correction standard determined by the SAE. This standard has been stable for a long time and is widely used in the performance industry. Power is corrected to reference conditions of 29.92 InHg (103.3 kPa) of dry air and 60 F (15.5°C). Because the reference conditions include higher pressure and cooler air than the SAE standard, these corrected power numbers will always be about 4 % higher than the SAE power numbers. Friction torque is handled in the same way as in the SAE standard.
· ECE (European Community), Europe. The ECE standard is based on the European Directives. Power is corrected to reference conditions of 99 kPa (29.23 InHg) of dry air and 25°C (77 F). Friction torque is not taken into consideration at all.
· DIN (Deutsche Industrie Norm), Germany .The DIN standard is determined by the German automotive industry. Power is corrected to reference conditions of 101.3 kPa (29.33 InHg) of dry air and 20°C (68 F). With the advent of European legislation and standards, national standards such as the DIN (formerly widely used) are now less significant.
· Actual You may see this on some charts. What this means is this is the actual horsepower achieved on the day tested and no correction factor has been applied. One can assume better or worse results with varying weather conditions.
rmbuilder is offline
Old 07-27-2004 | 06:49 AM
rmbuilder's Avatar
MarineKinetics
LarryD,
The actual formula for SAE J1349 can be found here:
http://wahiduddin.net/calc/cf.htm
Bob
Old 07-27-2004 | 04:51 PM
LarryD
thanks rmbuilder I already know the info in your first post but what I was after was in your second post thank you very much
Larry SVL #5
jcimprover
3
08-28-2005 07:56 PM
bouyhunter
12-13-2002 02:15 PM
PhantomChaos
09-24-2002 08:37 AM
glassdave
06-11-2002 10:03 PM
