-   -   Drive oil reservoir puking! (https://www.offshoreonly.com/forums/general-q/84393-drive-oil-reservoir-puking.html)
BadDog 08-03-2004 10:51 AM
Re: Drive oil reservoir puking!
I am with RHC on this one. You may have a problem, the heat will cause expansion and overflow. Drain and inspect oil and magnets. If you feel lucky swap bottles and see if it still pukes. I had an XZ puke twice and then lock up due to a pinion bearing. There was no metal flakes or chunks, just dirty oil as the pinion ground away to fine powder.
Tim T.
candyman35 08-06-2004 03:39 AM
Swap the caps and see it the problem switches sides. If not check the seals on the fill plugs.
Dan
baronbob 08-09-2004 10:40 PM
I had the same problem with a bravo III and went through all of the above suggestions. Then someone informed me that the cap has a special gasket and relief valve. I found the gasket as it had fallen between the cover and the intake manifold, I put it back into the cap and the problem went away.
OkieTunnel 08-09-2004 10:49 PM
I'm gonna switch lids this wekend and see. If its a drive I hope it can last until after labor day! I will try draining oil and see if there is some water in there.
BulletProof 08-09-2004 10:51 PM
i had the same problem..couldnt figure it out..till the drive blew up!! looked into it and best i can tell, cone clutch was slippipng and causing the heat..anyone know a good deal on some drives?? I am in the market
Roger..you dont drive that thing hard enough to know about any of this stuff do ya ;)
hope yall are well!
X-cited 08-10-2004 07:17 AM
I am experiencing the same problem. Switched caps and problem followed the cap. I need to search for that gasket or buy a new cap.
OkieTunnel 08-15-2004 08:49 PM
This weekend I switched caps and noticed a missing gasket on the side that was puking. I tightened them both down real tight and no puke after running all weekend. :D
