Merc 330 TRS Lower Crank PS pulley >
Old 08-03-2004 | 09:43 PM
nova454
Default Merc 330 TRS Lower Crank PS pulley
Does anyone know a solution for the lower crank power steering pump add on pulley for the 330 TRS. Mercruiser wants $265 for this pulley. Mine is bent and eating belts. How rare can this part be.
Old 08-04-2004 | 05:12 AM
Mbam's Avatar
Offshoreonly Advertiser
Default Re: Merc 330 TRS Lower Crank PS pulley
I think I have a nice used one, only problem is finding it. I will take a look. In the long run you are problay better off replacing the whole thing with a 3 groove billet pulley, belt lengths wil be differant thouhg.
Mbam is offline
Old 08-04-2004 | 07:15 PM
nova454
If you find the pulley let me know, I toyed with the idea of replacing the pulley with billet, but that throws off the spacing with the raw water pump, alterator and power steering. You can find after market automotive add on pulleys but only for SB Chevy SWP. The Mercruiser primary lower pulley with the first two groves have wider spacing then the automotive pulley.
Old 08-04-2004 | 08:59 PM
puder's Avatar
speel chekk this fokker!
i thinkihave one if marc can;t find the one in his shop.
Pardon me, while I whip this out!
puder is offline
Old 08-05-2004 | 08:25 AM
nova454
puder, let me know if you find it, The constant squeal of a loose power steering belt can grate on your nerves
Old 08-05-2004 | 08:33 AM
CHAOS REIGNS's Avatar
i just replaced one not long ago -- we have lots of boat repair places around where i live -- so i just took one off an old pump laying in a boat -- cost me my time and 20 bucks
CHAOS REIGNS is offline
Old 08-05-2004 | 12:47 PM
nova454
Chaos the pulley I am looking for is an add on pulley to the Crank Pulley. The owner before me swapped out the engine and bent the outer crank Pulley. Merc. made this pulley in two parts the inner pulley has two belt channels then an outer add on pulley for the Power Steering. I already replaced the power steering pump when I found the bend in the crank pulley. Thanks for the ifo.
BERTRAM BOY
Wanted
4
05-15-2008 03:30 PM
poolshrk
04-06-2008 11:34 AM
Prowler
Wanted
0
02-05-2008 10:22 PM
slik22
Wanted
2
01-08-2008 06:03 PM
klmken
1
06-28-2005 05:28 PM
