anyone use seastar hydraulic steering >
Old 08-18-2004 | 05:45 PM
KNOT-RIGHT's Avatar
Default Re: anyone use seastar hydraulic steering
I ran Seastar on my outboards for years. However, Mcollinstn's Dead on!
Running that type of I/O you would want the Strength
of external. Look at the picture of the the XS Performance system. It attaches right at the outdrive. with twin cylinders. Now open your hatch and look at your system. Have someone shake the outdrive while your in there. Then make your decision.
Good Luck
Gerry
KNOT-RIGHT is offline
Old 08-18-2004 | 06:39 PM
Infomaniac's Avatar
Why couldn't you just buy the brackets and mount the sea star cylinder external?
Mine is manual hydraulic. No worry about pump or belt failure. It check valves both directions. It stays in whatever position you leave it. Rock steady.
Infomaniac is offline
Old 08-18-2004 | 08:57 PM
mcollinstn's Avatar
You can mount Seastar or anybody else's cylinder externally.
What you run into, though, is that you need a cylinder with LOTS more travel for an external mount versus an internal cylinder. THEN you need a helm pump that is sized to work with the long travel cylinder so you don't have to spin the wheel six times to get it to turn. AND you gotta get cylinders that are made of materials to endure the severe environment on the outside versus the placid conditions inside.
There's a reason that external steering is costly.
mcollinstn is offline
Old 08-23-2004 | 08:16 AM
WildThing's Avatar
Originally Posted by Formula78
Anyone have an idea what the price tag is on the XS Performance system for a single I/O?
I think they are just under $3000.00 for a full, to the helm, system.
Certainly the best bang for the buck available in steering systems.
I do know these are priced much lower than the others out there, and the XS Performance system is one of the cleanest looking & heavy duty systems available. You can call Brian or Allan anytime and they will give you the correct pricing.
Ron
WildThing is offline
Old 08-23-2004 | 04:46 PM
I just installed one of brian`s steering systems on my boat. he is great to work with and does what he says. his systems are double ram . my system is working great .
speedball is offline
PARADOX
09-06-2007 06:46 PM
26sonic
Sonic
1
05-03-2006 10:09 PM
Whiteknuckle
49
12-07-2005 07:16 PM
CHAOS REIGNS
5
12-11-2002 07:56 PM
THRILLSEEKER
11
07-11-2002 07:12 PM
