overheats at startup/vent,then OK???
One of my motors gets NO water until I remove one of the hoses going to the exhaust from the thermostat housing(aftermarket). I run a crossover peice and have great pressure 25psi after but none at idle. I may have hurt my impellor but it is new as is the plastic housing. Do the little balls on a spring in the stock housing keep the water in the motor after shutdown? Seems vapor locked or something??My therm-stat housing only has 2 out for the exhaust.Like I said,if I remove one hose,let it run a few secs it starts to circ then I am good for the day. Next day ,same prob,same fix. Just a weak pump? I don't know. My stat has 4x1/8" holes drilled in the edge and is a 140 deg.
OK,Pump is perfect,just took it apart. You can feel it pulsing air and if you remove one of the hoses from therm-stat housing and after it gets hot and you rev it up a few times HOT water comes thru then it's good for the day. Show 0 at idle and up to 30 psi at speed. Confused.........
rocketkid
22
07-21-2011 01:43 AM
