Engine gurus!!!!!!!!!! >
Old 09-19-2004 | 08:48 PM
  #51
mikes280's Avatar
Default Re: Engine gurus!!!!!!!!!!
Originally Posted by jryan26
Your right about that. Is the ratio determined by the lower, or do you have to do both uppers and lowers?
depends if it is xrs it is in the lower f it is standerd bravo 1 it is in the upper
mikes280 is offline
Old 09-20-2004 | 12:15 PM
  #52
back to the original boat in question the theoretical speed for the equipment listed is 78.7 mph. the drive must be 1.36 because with the rest of the equation in place it would give you about 8% slip which should be about right for that boat. you should tear them down, count the gear teeth. probably change gears for best performance.
JIMG is offline
Old 09-20-2004 | 08:10 PM
  #53
jryan26's Avatar
JIMG
Its pretty amazing to me how close the calculator is.
jryan26 is offline
cloudmaster_321
11
08-03-2008 04:31 PM
dykstra
1
09-28-2005 04:32 PM
Shah Mat
15
06-26-2004 12:22 AM
formula31
5
06-16-2002 04:02 PM
