-   -   Nose cone adhesive (https://www.offshoreonly.com/forums/general-q/84825-nose-cone-adhesive.html)
aero-offshore 08-09-2004 02:11 PM
Nose cone adhesive
What adhesive do you use to reattach a nose cone? Also how do you drain the lube from a outdrive with a nose cone? Thanks, Buck
BajaRunner 08-09-2004 02:33 PM
Re: Nose cone adhesive
The nose cone should have a hole where the drain is. mine does.
aero-offshore 08-09-2004 02:49 PM
I wounder if they bondo that to. Thanks
Cord 08-09-2004 02:51 PM
That's assuming you don't have the drain behind the prop. My older drive had the drain up front, and there was just a hole in the cone to access the recessed drain plug. I was told to fill the hole with silicone to improve the aerodynamics. I believe my hydromotive nose cone came marinetex expoxy. The stuff never set up right for me, so I had it tack welded on.
aero-offshore 08-09-2004 02:55 PM
My drive is a bravo 1, 2000. Thanks Cord.
