Backpressure on a 502 mag efi >
Old 08-09-2004 | 10:19 PM
Excalibur502mag
Question Backpressure on a 502 mag efi
My 1999 502 mag came from the factory with straight 4" exhaust the transom only has flappers. It is very loud, and I like it this way, but an auto mechanic friend thought I might need some exhaust tips for backpressure. He says that most engines need a little to perform correctly. Is there even any baffles in the factory system? All I can see is the 4" rubber hose from the manifolds back.
Old 08-09-2004 | 10:23 PM
OkieTunnel's Avatar
Default Re: Backpressure on a 502 mag efi
I had a 454 mag which ran straight through and it ran fine. OK now I see "Auto mechanic" friend of yours! You don't need any back pressure to make a 454 or 502 mag run right. They are designed for straight exhaust.
OkieTunnel is offline
Old 08-09-2004 | 10:48 PM
Excalibur502mag
Thanks,
I am considering mounting a tip like this to take the sound down a touch for my nieghbors. Will it affect my performance or top end?
Suggestion are greatly appreciated
Secretformula
08-27-2008 03:38 PM
Boatally Insane
17
01-15-2005 01:28 AM
Smitty
2
08-20-2004 06:04 PM
Aces & Eights
Baja
2
08-06-2002 11:02 PM
