-   -   Anti-siphon Valve, Where Is It? (https://www.offshoreonly.com/forums/general-q/85014-anti-siphon-valve-where.html)
f252tbird 08-11-2004 03:28 PM
Iv'e Been Told The Anti Siphon Valve In My Fuel Tank Is Clogged And Needs To Be Replaced. Don't Know Where It Is Or How To Do It. Help Please.
Turbojack 08-11-2004 03:40 PM
Re: Anti-siphon Valve, Where Is It?
Most time I have seen them is right on the tank with the fuel line attached to it.
f252tbird 08-11-2004 03:58 PM
My Fuel Line Attaches To A 90 Degree Fitting On The Tank Is This It?
Formula29 08-11-2004 05:08 PM
yes, that is it!
Turbojack 08-11-2004 05:31 PM
The last one I saw was anti-siphon/hose bib all in one. When taken out there will be a ball in the middle of it.
jhnrckr 08-11-2004 05:41 PM
Mine was on the top of my tank, right next to my fuel level float underneith an access panel in my floor. I doubt it is clogged but it is restrictive and your motor will start much easier without it.
f252tbird 08-11-2004 06:28 PM
Ok, Next Question. Is This Separate From The Pick Up Line Or Will I Need To Replace The Entire Piece?
US1 Fountain 08-11-2004 06:53 PM
Should just be a screw-on fitting
How do you know it is clogged?
Liberator21 08-11-2004 08:39 PM
I just had this same issue a couple of weeks ago. Mine was a combination anti-siphon/ hose bib screwed into the 90 degree fitting on the tank. It looked fine when I took it out, but I replaced it with an Evinrude/ Johnson factory replacement part. It's a quality brass unit, and the opening in the hose bib was a bit larger than the old aluminum one that was on my tank. Needless to say my stalling problem went away.:)
