-   -   What t-bolt module do I have (https://www.offshoreonly.com/forums/general-q/85025-what-t-bolt-module-do-i-have.html)
Shah Mat 08-11-2004 06:14 PM
I bought it from a member here and wrote it down but can't find my paper.
Here is the #
6D04A V6-14
I read this part # with a mirror on back of the the starbord cylinder head so I'm not sure those numbers are 100% correct.
I have 24*@ 800rpm, 30* @1000, and 32* @ 3000, and that's assuming my 1989 VDO OE Checkmate tach is correct.
Does anyone know the advance curve of this module?
MrCIG 08-11-2004 06:37 PM
Re: What t-bolt module do I have
It is a 14deg advance that is what the 14 stands for. If you have 24 deg initial then you are at 38 full advance. Sounds a little high unless you got good fuel and aluminum heads.
Shah Mat 08-11-2004 06:40 PM
Hmmmm, when is full advance?
US1 Fountain 08-11-2004 06:47 PM
Around 3000rpm
With a timing light, raise the rpm until the timing mark no longer advances. That is the more prefered timing procedure than at idle as most are accustomed to.
Theoritically, initial timing at idle + the built in advance of the module= full advance timing.
cooltoys61 08-11-2004 06:48 PM
if you have it on a v8 it's only 6-10 adv from initial. When in water,check your total advance.Some adv all the way up to 4500rpm.
Shah Mat 08-11-2004 06:50 PM
Be back in a minute, I'm going to double check the readings.
Biggus 08-11-2004 06:51 PM
I've been running the V-6 modules for a few years. They will advance 14 degrees only when installed on a 6 cyl. When installed on an 8 cyl they will only give you 8-10 degrees.
I have them on my blower motors. all the advance is out by 3000.
Kurt
Shah Mat 08-11-2004 07:14 PM
28* @ 900, 32@ 1500, 32@ 2000, 32* @ 2500, and 32* @ 3000. I'm not gonna rev the motor past 3k to check the timing. It should be there as far as I'm concerned.
I have suspected my tach being off with my previous motor, but being a well experienced auto mechanic and judging by ear, I am pretty confidant the tach is somewhat close. Like + or - 500 rpms.
BadDog 08-11-2004 07:45 PM
24 at 800? The module is not advancing at 800 so your base must be close to 24 and your total advance around 8 as Biggus says. It may advance more above 3000 indicated. Better check. You could also look at a Crane HI 6M.
sonic28 08-12-2004 07:48 AM
im interrupting ok i have 24 degree module when i set the intial timing the book states 4 degrees i guess my question is at idle i use the light and set it at 4 and when the rpm is at 2500-3000 my total is 28?help
Shah Mat 08-12-2004 09:06 AM
Yes, that is correct. Total timing is advance + base. I'm not sure about at what RPM each module gets to full advance though. Someone on this board probably knows the specs of all Merc modules. Biggus says mine is fully advanced at 3000.
Iggy 08-12-2004 10:57 AM
Total advance occurs at different rpm's,
V8-20R is 20* @ 5250
V8-HP is 20* @ 3000
V8-22 is 22* @ 4500
V8-22A is 22* @ 3500
V8-24 is 24* @ 3750
V8-24S is 24* @ 5000
220BR 08-12-2004 08:42 PM
Iggy, I'm curious, the numbers for the 22 and 22A are a$$ backwards between the Merc service bulletin and Dennis Moore's book. Which source are you relying on?
I've never taken the time to actually check with a timing light even though I run both from time to time.
