Starter for a 540 >
Starter for a 540
Starter for a 540
Old 08-14-2004 | 10:15 AM
Vinny P's Avatar
I hate the winter!!
Default Re: Starter for a 540
mopower,
You are right, I do remember that. You can't do that anymore with newer cars. It sucks getting old.
Vinny P is offline
Old 08-14-2004 | 10:58 AM
Hey Clearman! Are you saying my motors aren't "built"?
Lmarth is offline
Old 08-14-2004 | 11:03 AM
Now that I think about it, those GM starters didn't have any trouble starting my 12:5 to 1:00 BBC's when I was road racing. All kidding aside, you do need a little extra oompf every once in awhile.
Lmarth is offline
Old 08-14-2004 | 12:16 PM
JimV's Avatar
I tried the tilton starters and work good when they are new. Over time big problems. There really not meant for marine although they are sealed. I got stuck on the dock at a poker run and had a hell of a time getting parts at the local parts store. The motors used are out of a import car. The stock starters are available pretty much anywhere. We use a timing retard with no problems.
JimV is offline
Old 08-14-2004 | 06:13 PM
mopower's Avatar
Toxic FORMULA
Originally Posted by checkmate454mag
mopower,
Yeah , tell me about it
mopower is offline
Old 08-14-2004 | 06:36 PM
mopower--I'm with you!
Lmarth is offline
Old 08-14-2004 | 06:53 PM
mopower's Avatar
Toxic FORMULA
Lmarth,
Sorry about your luck
It takes me all night to do what I used to do all night
mopower is offline
Old 08-14-2004 | 09:49 PM
HeavyChevSS
What about the Mercruiser starters, would have to look up part number but the one used on the old 540" HP500 worked fine. I second the motion of cranking 10 secs until you get oil pressure..
Rick
Old 08-15-2004 | 05:58 AM
Vinny P's Avatar
I hate the winter!!
I checked out the part #'s for the factory Merc. starters. They are they same all the way to and including their 800SC motors. I guess that my starter from my 454 Magnum will do the job. I just never thought about using it.
Vinny P is offline
Old 08-15-2004 | 07:22 AM
RLW
Well Checky, let me give you some insight on using the stock starter on your Dart block.
If your starter has the hanger bracket located on the rear of housing, you are going to have to drill into the boss on your new block and tap a hole in order to use the bracket. I went to use my relatively new 10MT style starter on my Dart block and that is what I discovered.
Then, Jpclear tells me about how his stock starter sometimes has a tendency to groan while it tries to start his 540 when warm. He recommends this outfit called MES Marine, to get one of these "mini high torque starters (which is a whole other story. see attached photo). After a lot of screwing around, four starters and a ring gear later, I ended up with the CVR.
While your motor is out and you have to drill and tap the block, now is a good time to check your gear lash between the starter and the ring gear. Also check your bolt length to insure that the starter is firmly mounted and there is zero clearance between it and the block. Make sure that the bolts are not bottomed out in the block.
Remember, you are turning over a lot of mass and surface area with a 540.
I am not saying what I did is necessary. I just figured that an 11 lb. 90 amp starter was a better way to go than the 19 lb. 325 amp starter.
Have fun!
Russ
RLW is offline
