Starter for a 540 >
Starter for a 540
Starter for a 540
Old 08-13-2004 | 07:16 PM
Vinny P's Avatar
I hate the winter!!
Default Starter for a 540
I am getting started with building my naturally aspirated 540 . It will have 9.5 compression, standard 168 tooth flywheel. Who's starter is everyone using?
Vinny P is offline
Old 08-13-2004 | 08:26 PM
mopower's Avatar
Toxic FORMULA
Default Re: Starter for a 540
I've got the same engines and use stock starters (two seasons old)
mopower is offline
Old 08-13-2004 | 09:42 PM
RLW
Tiltons are good starters but then I discovered CVR starters. I am not knocking Tilton Engineering. Having had both a Tilton and a CVR in my possession, I would go with the CVR product.
The starter comes in a shrink wrapped package inside a cardboard box with complete instructions. Starter has more adjustability for a custom fit. The gear ratio is 4.4:1 while the Tilton is a 3.75:1.
CVR and Tilton both offer 1.9hp and 3hp models.
Tilton recommended that I buy the 3hp Severe Duty after they first recommended their 1.9hp version (which I had purchased).
I wasn't sure what I needed.
The CVR distributor, Racers Depot, seemed more in tune with the applications of the CVR product line. They said no problem using the 1.9hp version due to the 4.4:1 gear reduction.
Less expensive than Tilton, I paid $270.00 shipping included.
The CVR Protorque, Part # M5323, is what I put on my 540.
Call Racers Depot for CVR Starters at 800-235-0880.
http://www.cvrproducts.com/main.html
http://tiltonracing.com/superstarters/sonicflex.html
RLW is offline
Old 08-13-2004 | 10:05 PM
Vinny P's Avatar
I hate the winter!!
Great information. Thanks alot
Vinny P is offline
Old 08-13-2004 | 10:34 PM
mopower's Avatar
Toxic FORMULA
Question Re: Starter for a 540
Are these starters explosion proof for marine use
I've also used high torque starters and had a hydrolock problem (manifold leaking)that turned into change the ring gear because the starter literally ripped teeth off
My conclusion was , with 9.5 CR there's nothing wrong with stock plus it is easier on parts.
mopower is offline
Old 08-14-2004 | 06:01 AM
Vinny P's Avatar
I hate the winter!!
mopower,
True that 9 1/2 is not alot of compression, but what about the extra cubic inches? How long will a stock starter hold up?
Vinny P is offline
Old 08-14-2004 | 07:12 AM
That's great information guys for future reference. For what it's worth, I bought a 1998 boat in 2000 with 800SC's and stock starters. Never had a problem with them. Not only that, but when the motors are cold, I crank them until I have oil pressure before I start them.
Lmarth is offline
Old 08-14-2004 | 07:20 AM
Vinny P's Avatar
I hate the winter!!
Lmarth,
That's good to know. I never would have thought that could be.
Vinny P is offline
Old 08-14-2004 | 09:30 AM
Remember, most blower motors start out with much less than 9.5 : 1 CR so they will crank much easier than a built NA motor. --- JP
jpclear is offline
Old 08-14-2004 | 09:38 AM
mopower's Avatar
Toxic FORMULA
Most stock starters should work fine. If you're old enough to remember stick shift cars before they had safety switches on the clutches , you could put one in 1st gear and the starter would move the entire vehicle
mopower is offline
