Clack, clack, clack... >
Old 08-16-2004 | 03:16 PM
rchevelle71's Avatar
Default Re: Clack, clack, clack...
Originally Posted by hi-perf-2000
Internal exhaust flappers???????
DING DING DING !!!!!!! I think we got a Winner!!!!
I just dont want this guy to tear his engine down, 'til he rules out easy Chit!!!
rchevelle71 is offline
Old 08-16-2004 | 03:31 PM
thebigtman's Avatar
The "tips" stick out about .5" and they have a rubber flap on them. The exhaust comes out of the riser toward the rear, makes a dip downward and then back straight through the hull.
When I looked in the exhaust last night I couldn't see any flappers. The exhaust has a rubber hose that connects to a metal pipe that bends downward and back and then another rubber hose. Would there be flappers that far up in the exhaust so you can't see them?
thebigtman is offline
Old 08-16-2004 | 03:38 PM
Take a pic!!!
there shouldnt be flappers up that far, but if its what I think your explaining, there could be diverters??? could be something loose, but less likely than the internal flapper noise.
Old 08-16-2004 | 03:58 PM
thebigtman's Avatar
I don't have a switchable exhaust.
I tried checking around for something loose but I couldn't find anything. I looked up front near the accessories...nada. I looked near the output shaft and nothing there either. When it happened at the lake I looked around for over an hour trying to figure it out. I can't tell if the the noise is coming from port or starboard either.
I don't have a digital cam handy but I'll see what I can do tonight. Thanks for the responses so far though.
Old 08-16-2004 | 04:09 PM
thebigtman's Avatar
http://216.37.204.201/mercruiser_oem...111&A=113&B=13
That's what the exhaust looks like.
Old 08-16-2004 | 04:16 PM
There is a flapper in the Y-pipe...
BadDog is offline
Old 08-16-2004 | 04:19 PM
thebigtman's Avatar
So, should I pull the elbow and inspect it?
Old 08-16-2004 | 06:08 PM
HeavyChevSS
Hopefully isn't anything too bad if it's not loud enough to hear outside the boat. You can "listen" to the valve covers or different areas using a long wooden handle screwdriver or long wooden dowel. Think of it as a caveman's stethoscope...If all else fails might run a compression check or pull valve covers to rule out bent valve.
Old 08-16-2004 | 06:41 PM
blue thunder's Avatar
Originally Posted by thebigtman
. A few of the plugs were a little loose when I checked them but other than that, they were ok and the boat ran fine with them.
Now I'm stuck.
Tim
Loose plugs are a danger sign of detonation. Electodes changing gap can be too. Just a thought. These observations should be a huge red flag to look at a/f mix, fuel quality and ignition control.
BT
blue thunder is offline
Old 08-16-2004 | 06:45 PM
thebigtman's Avatar
Thanks for the suggestions. I'll check it out ASAP. The plug color looked good. I pulled the valve covers yesterday and everything looked kosher. I did tighten up the rockers since they were a little on the loose side but it didn't make a difference in the noise.
Tim
