Kaama Question >
Kaama Question
Kaama Question
Old 08-16-2004 | 12:20 PM
boatinbabe04
Default Kaama Question
undefined
Hi all,
I have a 1983 Scarab II with Kaama surface drives, one with a leaky boot.
I'm not sure where to find a replacement. The drive is already off (thanks to three broken bolts!) and would rather just get a new one instead of repairing it. Any suggestions. I have been searching the internet all day and can't find anything!
Thanks in advance
BB04
Old 08-16-2004 | 01:13 PM
phughes69's Avatar
Default Re: Kaama Question
Find CUDA on the board. He has a Formula with surface drives and knows a ton about them.
phughes69 is offline
Old 08-16-2004 | 02:19 PM
BBO4 hi there! You will have to call Team Archer Marine 949-646-9778 they supply them when they have them, they might be back logged. I now Cuda was waiting for some.
Jim
kaamaman is offline
Old 08-16-2004 | 03:25 PM
X-Rated30's Avatar
I repaired one about 4 years years ago, and it has been working great. Don't fret if you have to go this route. Archer is the only one I know of that makes the replacement.
X-Rated30 is offline
Old 08-16-2004 | 04:48 PM
Originally Posted by boatinbabe04
undefined
Hi all,
Thanks in advance
BB04
Team Archer Marine in California has parts for them. Not sure of the phone number. do some research and you will find the number
otis311 is offline
Old 09-08-2004 | 10:06 AM
alj's Avatar
alj
You need to look at a couple different forums and you will get well aquainted with all things KAAMA. The Formula forum probably has the most info on KAAMA surface drives because Formula offered the drive package on a number of different boat models. F302 KAAMA, F402 KAAMA, F311 KAAMA, and F357 KAAMA. Do a search on member 'Cuda'. He has a 1985 F302 KAAMA that he recently posted a picture by picture rebuild of the KAAMA drives and boots. Kaamacat also helped me with his blow by blow rebuild instructions on the hydralic rams including the part numbers for the seals so I could get them through a local bearing and seal company. I think it was Kaamacat that sent me the service and maintenance manual for Kaama drives as well. There is a lot of info on Offshore Only. Most of us with KAAMA's have been through something that we can share and help others with. Post a pic of your Scarab!
alj is offline
Old 07-08-2006 | 05:13 PM
I have a 1988 FORMULA SR311 with KAMA surface drives and one of the hydraulic rams that raises and lowers the drive has blown the seal and fluid is running out and down the drive. I would like to replace this one or repair both of them since the seal on the other one does not look any better but for now is holding, can you help me. thank-you DAVID at [email protected]
heyartdude is offline
Old 07-08-2006 | 05:39 PM
TeamSaris's Avatar
Driver-441
Racer
We might have one. 518-644-3080
We built big blower motors for the same setup as Cuda. 90+ sshe is stable as a rock!!!
TeamSaris is offline
Old 07-08-2006 | 06:58 PM
cuda's Avatar
Do you know where to get a boot? No leaks right now, but I'd like to keep a spare. Any Kaama housings? Again, just for a spare.
cuda is offline
RiverRat311
4
06-23-2006 10:56 AM
mopower
02-03-2005 10:10 PM
JJONES
07-17-2003 06:21 AM
X-Rated30
06-07-2002 01:39 AM
