-   -   Eagle Rotating Assembly (https://www.offshoreonly.com/forums/general-q/85425-eagle-rotating-assembly.html)
Comanche3Six 08-18-2004 05:45 PM
Re: Eagle Rotating Assembly
Junk
Cmoney 08-18-2004 05:56 PM
Thanks for the detailed info!
WETTE VETTE 08-18-2004 08:26 PM
All cranks need to be checked before the engine is built. I have run Eagles in numerous motors with no problems, and these have been 6000+ RPM engines. Running top dollar parts shouldn't be a reason to not go over all tolerances and clearances with a fine tooth comb, and that is the responsibilty of the engine builder. I have heard of problems with Lunati, Callies, and other cranks, but likely those problems are build problems rather than crank problems. If you trust your engine builder as being competent then spend the extra money on heads or something that will give you a few more HP. Just my .02!
Craig
Back4More 08-18-2004 08:36 PM
He's way high on that price.
http://www.flatlanderracing.com/
WETTE VETTE 08-18-2004 09:23 PM
$2300 should be a price for a complete assy. including bearings and balancing. If that is just for the crank, rods, and pistons he is high as B4 more has mentioned.
Cmoney 08-18-2004 10:23 PM
Yes that is complete assembly, rings, bearings ect.
wirsboguy 01-30-2009 12:32 PM
Hey, ateco just posted an add for A 540 rotating assembly for somewhere aroun $1750. check them out. He is using scat crank and J/E SRP pistons. top of the line in my opinion. I think
he is in the deale or advertisors section
DareDevil 01-30-2009 12:37 PM
Originally Posted by Cmoney (Post 1040777)
I am going to have two 540's (tall deck) built this fall by a local engine builder. He gave me a list of what he is going to use, everything sounds good except I am reading some negatives about the Eagle rotating Assembly (mainly the crank).
It is going to be a mild 540 about 580hp, will I be alright with the Eagle crank?
I had real bad luck with eagle !!!! Broke the crankshaft right in half !!!!
Bulletproof is Billet !!!! Scat or Crower !!
And its not about the HP or Tourqe it was because of 6 footers running at 75-80 !!
Would not use eagle anymore unless in a 300 HP fishboat.:eek:
wirsboguy 01-30-2009 12:44 PM
Ateco engines have the WHOLE assembly for $1750. Scat crank and J/E SRP pistons...the GOOD stuff
5050 01-30-2009 01:13 PM
if you are starting from scratch, instead of 540 build some mild 572s:rolleyes:
