Bravo bell housing support bushing >
Old 08-23-2004 | 12:33 PM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
Default Bravo bell housing support bushing
well the saga continues
I am just ready to install the motors and notice a worn out bushing in the bell housing (the one that is steel outter race rubber then steel inner race) and mounts the drive to the transom plate I take it to work press them out Well one comes out the other three the inner comes out but no outer on 2 and the outer 1/2 way out one of them.
Any clue on how to get the outer race out on the ones that did not move the shoulder it goes against is of larger id then the outer race so I cant push on it I was thinking die grinder and split it
That sucks
I had heat on it they were locktited in but they still seperated
Its still fun thought in a weird way
Just think when I am done I will have enough cash to buy all the tools for home that would have made this job easier
klaw is offline
Old 08-23-2004 | 12:42 PM
merlin540
Default Re: Bravo bell housing support bushing
take a die grinder and carefully split the race and it will come out. take your time and dont grind into the housing seeya
Old 08-23-2004 | 12:55 PM
klaw's Avatar
should you use locktite when reinstalling and iof so what variety
klaw is offline
Old 08-23-2004 | 01:27 PM
merlin540
i would use green seeya
Old 08-23-2004 | 06:17 PM
klaw's Avatar
ok so I am stupid when I pushed old ones out I pushed on inner bushing no knowing they had a pusher ring that is installed first that let you press on the outer race (it looked like a piece of bell housing
Merc manual was no good I found this out after I had cut old ones out and opened new ones and saw this funny little ring
who would of thunk
klaw is offline
offthefront
Wanted
6
11-07-2008 06:51 PM
Sick Stinger
08-27-2008 06:59 PM
kmiller
8
06-28-2007 08:50 PM
Scarab28
1
07-03-2005 11:14 PM
cheitman
21
01-13-2003 12:21 PM
