Bravo Rotation >
Bravo Rotation
Bravo Rotation
Old 08-23-2004 | 01:58 PM
rappinleroy
Default Bravo Rotation
I understand that Bravo drives are designed to run either direction. What is the opinion on changing the shifter linkage to run a LH rotation prop on a drive that has 100+ hours of RH prop hours on it? I see some great deals on single LH props.
In one direction the top gear would be trying to push the top cover off and the other direction the lower gear would be getting forced down against the housing body. Wouldn't the design favor the lower gear being used as the 'normal' rotation?
Is there any data that shows a reliability difference?
Old 08-23-2004 | 02:17 PM
Default Re: Bravo Rotation
Good question, there are some drive experts and builders on the board. Let me add to your post. Is there a concern in changing direction after several hundred hours? Do the gears like to be turned the same direction for their lifespan?
BadDog is offline
Old 08-23-2004 | 04:59 PM
merlin540
we usually switch them side to side every season and have had great results
Old 08-23-2004 | 09:55 PM
Tinkerer's Avatar
I switch mine yearly also.
Tinkerer is offline
Old 08-24-2004 | 07:38 AM
rappinleroy
Thanks for the replies. I guess it is just a little un-nerving for me to run my drive in 'reverse' for a LH prop, but it make sense that twins are doing it all the time.
Stay cool ... keep the juices flow'in
Run_em_hard
Drives and Lower Units
13
06-05-2023 12:31 PM
formula31
10
02-14-2008 08:36 AM
RHICKOFF
2
01-05-2005 08:49 PM
ursus
1
06-13-2003 03:34 PM
Tantrum
2
03-28-2003 10:29 PM
