Big BLock Chevy water pressure? >
Old 08-23-2004 | 09:25 PM
homan
Default Big BLock Chevy water pressure?
cruising at 3k rpm what should water pressure be with a stock Mercruiser sea pump, w/pump crossover no stat and Gil dry pipes
Old 08-23-2004 | 09:45 PM
Default Re: Big BLock Chevy water pressure?
the pressure should be arond 10 to 15 psi with a cross over and no stat. if pressure is to low check the pump and the water inlet ( drive ? or transom pick up) if pressure is to high check for a restriction in the engine or the exhaust
CMS Racing is offline
Old 08-23-2004 | 09:53 PM
homan
I'm getting about 4-5 lbs. w/new impeller
Old 08-23-2004 | 10:07 PM
What Kind Of Water Pickup Are You Running . Outdrive Or Transom Mounted
Old 08-23-2004 | 10:26 PM
What type of water pressure should you be getting with a transom mount pick up standard Mercury sea pump and wet Gil exhaust?
Active Mike is offline
Old 08-23-2004 | 10:32 PM
I forgot to mention no cross over pipe and at WOT.
Old 08-23-2004 | 10:38 PM
In Your Case What Kind Of T Stat Housing Due You Have And Due You Have A Stat In .
Old 08-23-2004 | 10:47 PM
Not sure on the t stat housing and thermo. What ever would be stock for a HP 500. I never had that apart.
Old 08-23-2004 | 10:57 PM
aproximatley 25psi at wot if every thing is right .the hp 500 housing has releif valves going to the gil exhaust risers. that hold the pressure to around 25psi.
Old 08-24-2004 | 12:00 AM
CMS,
Thats right about where she run's at WOT.
Thanks.
Strip Poker 388
Wanted
6
06-25-2008 07:09 AM
bryanspeedracer
66
12-30-2004 11:25 AM
horizontalboggi
5
05-12-2003 05:14 PM
Dennis Moore
32
02-12-2003 12:05 PM
