Charging system?? >
Charging system??
Charging system??
Old 08-27-2004 | 09:10 PM
Default Charging system??
While running the boat today I noticed that the voltmeter was climbing very slowly. It peaked out at about 16 volts. I have 2 batteries and a selector switch and the voltmeter did not change if I selected either battery or both battreries it stayed at 16VDC. Is the voltage regulator on its way out or is there something else I should look at?? Thanks for the help
tmthunder is offline
Old 08-27-2004 | 09:16 PM
baja2700
Default Re: Charging system??
The internal regulator went south. Mine just did the same thing. Pull it and rebuild it or go with one that has a higher current output.
Old 08-27-2004 | 09:48 PM
I was thinking of going with a higher output alternator due to stereo amp so it looks like I might be doing it sooner than I thought.
David Stotz
Drives and Lower Units
6
09-18-2007 05:05 AM
cloudmaster_321
14
05-27-2005 10:58 PM
482
1
04-13-2005 02:27 PM
38cigmike
1
08-03-2004 01:05 PM
pro design
3
01-10-2003 11:53 PM
