Correct prop ? >
Correct prop ?
Correct prop ?
Old 08-30-2004 | 05:09 PM
berns29scarab's Avatar
Default Re: Correct prop ?
the thing i cant get over is that i did the same numbers...first 4 adults 3/4 tank of fuel into a 6-8 mph head wind in a 1-2 ft chop...than 2 of us 1/4 - 1/2 tank of fuel 6-8 mph tale wind...almost like it doesnt make a difference on conditions thats what i'm gonna do reguardless
berns29scarab is offline
Old 08-30-2004 | 05:11 PM
i was told by somebody else the the mercury 4 blade is the way to go on this boat if i can turn one...not the hydromotive because they dont like a$$lift which is hydro's specialty
Old 08-31-2004 | 10:43 PM
HOUSTONPROP's Avatar
Talking Re: Correct prop ?
Originally Posted by tssteph
You are about right for what you have, I have the same setup.
Let Darin do the props, he did mine and I am very happy with the work.
No fuel, no gear down river with a tail wind 69.3 @ 4800, small amount of prop work by cheap local shop.
No fuel, no gear down river with a tail wind 71.3 @ 5000, after Darin worked on them. T would not hold it there but that was the fastest I could get 71.0 and hold it there, I had to trim a little more with no tab and would pickup a little more and then porpoise some.
The best things is that at 3200 rpm I picked up 3 mph.
great!!!!!!!!!!!!!!and Thanks for the plug. Darin
HOUSTONPROP is offline
Old 09-01-2004 | 05:31 AM
Payton's Avatar
Charter Member #927
A lot of boats will run faster going into a little wind. It gives you just a little more hull lift.
Payton is offline
Old 09-01-2004 | 08:54 AM
alter ego's Avatar
Darin did the prop on my 28 stryker. If midrange is what you want he can get it to you. I had a 23p Mirage and he did his magic to it. My cruise speeds are up 2-3 mph and the acceleration is awesome. I didn't gain top end but I'm not really worried about that as much. the boat planes easier and is much better when it gets rough now. Its worth it...
alter ego is offline
Old 09-01-2004 | 09:46 AM
throttleup's Avatar
If you want to try a Bravo I let me know. We have a prop fitting program available. Let me know if I can help!
Julie
throttleup is offline
doubletake
Cigarette
2
05-01-2007 10:22 AM
Toffen
Prop Talk
1
10-02-2005 11:30 AM
Onepass31
03-14-2005 07:48 PM
migara422
Pantera
8
04-29-2004 08:38 PM
Fast Forward
1
09-08-2002 10:04 PM
