trim cylinder hyd line leaking >
Old 09-12-2004 | 02:29 PM
Default trim cylinder hyd line leaking
trim cylinder line going through the transom cutout for the outdrive is leaking. the line operates the trim cylinder on the outdrive. the boat is a 1988 cigarette bullet with bravo one drives. do i have to pull the drive to repair the line.
riski bidness is offline
Old 09-13-2004 | 08:35 AM
Doller Offshore
Default Re: trim cylinder hyd line leaking
remove the manifold assy.at the base of the gimbal housing,you can get to all the hoses that way-------------art
Old 09-13-2004 | 09:11 AM
David's Avatar
If you buy one of those little brass flare connectors, connect the new one to the old one, and you can feed the new line in while pulling (carefully) the old one out.
David is offline
Old 09-13-2004 | 04:31 PM
thanks for the info guys
pullmytrigger
5
06-03-2008 01:47 AM
migara422
2
08-19-2004 10:30 PM
Twig111
2
08-17-2004 08:05 AM
johnnyboatman
3
06-20-2004 07:07 PM
fountain27ho496
0
10-10-2003 10:23 AM
