Re: high oil temperatures
Originally Posted by articfriends
Boatman,you said the port side of both pans spits oil? Are these hardin pans? I used the hardin 14 qt oil pan from cp performan\ce,it is suppossed to be a copy of the gil pan,when i installed mine i tried to use the nice felpro 1 piece gskt that i use on most motors but it fit TERRIBLE. I could actually slide a .010 feeler gauge betwen block and gskt,luckily i caught this while it was still on the stand. I bought another felpro 1 piece gskt and the fit was just as bad,i don't blame the gskt,i blame the pan,just curious if you ran into same problem. I ended up using cork gskt's with lots of black rtv,it doesn't leak but i wouldn't buy another hardin pan again. Patriyacht is right,are you running correct bypass valve set-up,there has been alot posted on here lately about near identical problems,good luck,Smitty
| All times are GMT -5. The time now is 08:24 AM. |
