Help Choose Engine Upgrades >
Old 09-15-2004 | 09:20 AM
hammer_34's Avatar
Default Help Choose Engine Upgrades
Option 1...R&R engines, port heads, install oversize valves, larger cam, Edelbrock inatke and Holley marine carb, Stainless Marine exhaust
Option 2...is exactly the same as #1 except the intake and carb is replaced with an aftermarket EFI system with 1100 CFM throttle body, 42 lb. injectors, FAST ECU with wide band 02 sensor
Option 3....Whipple install complete. Adding transom mount water pickup for intercooler and adding a large oil cooler
Which offers a good mix of reliability and speed to my 350 mags?
hammer_34 is offline
Old 09-15-2004 | 09:36 AM
Default Re: Help Choose Engine Upgrades
What outdrive is behind these 350 mags? If you have the ALPHA you are going to be limited.
1BIGJIM is offline
Old 09-15-2004 | 10:21 AM
hammer_34's Avatar
Bravo I
Old 09-15-2004 | 12:39 PM
Hammer
you didnt say what engine but if it is 350s consider a 383 stroker its just as simple you can use most of your existing parts and it has to be the least expensive way to go . I just finished water testing a customers boat yesterday that had sbc 350s and we upgraded to 383s they made with his heads 403 and 405 hp with 440ft lbs of torque the idle at 800 rpms and we ran on 87 octane he stated the boat had never had that throtle response and he could never maintain the cruising speed before like yesterday.You can buy these parts fairly inexpensively and the extra torque is always welcomed.Sincerely Laz Mesa www.mesabalancing.com
MESABALANCING is offline
schurgervt
0
02-02-2008 02:51 PM
Dueclaws
01-13-2008 11:36 AM
The Menace
04-23-2004 12:05 PM
turbo73
Fountain
2
02-08-2002 06:25 PM
turbo73
0
02-07-2002 01:03 AM
