Closed Cooling >
Closed Cooling
Closed Cooling
Old 09-21-2004 | 11:05 PM
2112's Avatar
Question Closed Cooling
OK guys, I have asked this a few times only to see the threads die.
Any body know of a straight forward closed cooling system with sanitary rigging?
It is just a heat exchanger correct? Could you not use something like the big teague oil cooler but run your engine coolant through the oil pasages?
Ideas?
2112 is offline
Old 09-22-2004 | 02:58 PM
Attack's Avatar
Default Re: Closed Cooling
This is a great setup.... Note exchangers on front of motors.
Talk to the guys at Innovation in Sarasota, FL
Attack is offline
Old 09-30-2004 | 09:17 PM
dirtyplumber
seakamp (econo-cool)remote mount you can put the exchanger just about anywhere in the boat.I got the full system with the big 5"x24"exchanger but modified the thermosat housing for 1/2 system.as far as sanitary you could tuck the exchanger down low on the side and use braided hose or bend some soft copper and paint it on the raw water side(1.25")and use that (be-cool)flex tubing/polished stainless radiator hose on the closed side. my engines still look like engines but the t.stat housing looks odd i think i'll go to a regular t.stat housing(car)with a bypass spacer underneath
big pain in the ass but looks cool even with black rubber hose.short dough as well
Old 09-30-2004 | 09:27 PM
dirtyplumber
actuallty i'll need t.stat housing with a radiator cap/fill
Old 09-30-2004 | 09:38 PM
2112's Avatar
Do you have any pictures?
2112 is offline
Old 09-30-2004 | 10:04 PM
Reed Jensen's Avatar
Ideas?
Teague doesn't build those... ask me and I'll send you a link to the manufacturer....... Lots cheaper.......
Reed Jensen is offline
Old 09-30-2004 | 10:55 PM
dirtyplumber
perfprotech.com has a more exspensive,maybe larger(hp systems)pictures on line.a little different from my set up but you get the idea
Old 10-01-2004 | 12:32 AM
2112's Avatar
OK Reed, I am Asking
2112 is offline
Old 10-01-2004 | 12:34 AM
2112's Avatar
Dirty
Look at resevoir on the viper motors in the 40' Hallett in the latest Powerboat mag. Stainless box with cap. Looks simple enough.
2112 is offline
Pokher Ace
8
10-17-2008 07:22 PM
Wodster69
8
04-23-2008 08:55 AM
sandcraft
10
04-05-2006 09:44 PM
alter ego
9
03-30-2004 05:58 AM
duker
2
05-31-2003 05:24 PM
