Bravo one questions >
Bravo one questions
Bravo one questions
Old 10-02-2004 | 06:27 PM
Unhappy Re: Bravo one questions
It's about $2,750.00 per drive if you don't do it right. I have receipts!
screebar is offline
Old 10-02-2004 | 06:46 PM
HyperBaja's Avatar
Default Re: Bravo one questions
Originally Posted by Dono
Where is the vent plug located? I took the props off and found the drain. If the bottom drain plug also drains the resivoir it only makes sense ( to me) that with the plug out you could run fresh fluid thru the drive as long as you didnt let the resivoir run dry. Anyone??
Why bother?
You want to risk blowing a drive because you are too lazy to do it the right way? Want the shop number?
Pull prop off
drain screw is behind prop (put drive down)
after that starts draining, open resevoir cap
dont need to undo the other screw, if you unscrew it too early you get a nice puddle of oil.
I have a DIY plastic kit in the garage never used, if you want it, pay shipping, and you will do it right.
HyperBaja is offline
seafordguy
Drives and Lower Units
5
04-03-2008 11:41 AM
sleepy_pirate
12
10-09-2006 01:40 PM
sleeper_dave
22
04-03-2006 06:08 PM
Mike Paula
5
08-26-2005 06:33 PM
mfb357
3
04-07-2004 06:15 PM
