Transom replacement >
Transom replacement
Transom replacement
Old 10-02-2004 | 12:01 PM
Default Transom replacement
Looks like I'll do a transom for winter project... it's leaking and soft at the bottom. It's an 86 Scarab III (34' tank)
I have a glass guy in mind that's just started up a business of his own this year and needs some winter work. He's described to me that he will start with a 3/4" plywood and glass it in, then another 3/4" plywood and glass it in too, etc.. until he's back to the original thickness. He said he'll be drilling holes in the plywood to make sure there is enough epoxy oozing throughout (good idea??). He also said he might need to make it in 2 pieces (see atachment). I've only seen this done in 1 piece... will this method be as good?
I'm going to remove all the hardware and he'll do the rest for $2k. Sounds good to me(?)
Anyway, I'm looking for opinions on this method... thanks.
jackhammer is offline
Old 10-02-2004 | 01:45 PM
SKRAMER's Avatar
Default Re: Transom replacement
I had the transom and an engine stringer replaced in my cigarette and it cost me $3000.00. I believe the two piece transom you are talking about would be fine. But the guys who did mine used the West Systems to epoxy the pieces together.Then glassed over them. Good Luck
SKRAMER is offline
Old 10-04-2004 | 07:13 AM
Audiofn's Avatar
Charter Member #232
That method is fine. The holes he is talking about drilling is a very good idea. It is more important in letting out the air.
Jon
Put your best foot forward!
Audiofn is offline
Old 10-05-2004 | 03:08 PM
If he can miter (cut with the saw blade at 45 or more degrees) the splices, it will be stronger.
Chart is offline
Old 10-14-2004 | 07:18 PM
monsta
if your on l.i inj newyork bring it to monsta, 516 799 6029
Old 10-14-2004 | 08:46 PM
VIPER7's Avatar
I had a transom replaced several years ago in a Formula and the plywood they used was marine grade with more plys than an exterior grade and they also epoxed the two pices of plywood together.
VIPER7 is offline
justice
Detailing, Painting, & Fiberglass
89
01-01-2010 03:49 AM
jez350
65
10-22-2007 08:41 PM
jackhammer
55
05-28-2007 07:46 AM
Double R Performance
Nor-Tech
1
08-02-2006 11:34 AM
later
7
02-27-2003 11:53 PM
