will running rich result in smoke >
Old 10-04-2004 | 02:54 PM
JGB's Avatar
JGB
Default will running rich result in smoke
coming out of the valve cover breathers?
JGB is offline
Old 10-04-2004 | 03:17 PM
mopower's Avatar
Toxic FORMULA
Default Re: will running rich result in smoke
No...but blow by will
mopower is offline
Old 10-04-2004 | 03:18 PM
robyw1's Avatar
What color smoke??
robyw1 is offline
Old 10-04-2004 | 03:20 PM
JGB's Avatar
JGB
whiteish/ grey
JGB is offline
JGB's Avatar
JGB
if it's blow by does that mean the motor will need to be rebuilt?
JGB is offline
Old 10-04-2004 | 05:02 PM
Turbojack's Avatar
Depends on how bad it is. Do a leakdown test & the results will give you your answer
Turbojack is offline
Old 10-04-2004 | 05:16 PM
JGB's Avatar
JGB
other than the smoke from the breathers the engine runs strong. Supposedly 40 hours on a rebuild.
JGB is offline
Old 10-04-2004 | 11:06 PM
robyw1's Avatar
That is oil and it does not have to do with being rich. How bad is it pumping out of there? just slightly or like Mt. St Hellen's?
Roby
robyw1 is offline
Old 10-05-2004 | 09:58 AM
JGB's Avatar
JGB
Roby, it's coming out of the breathers steady but not like mount st. helens.
JGB is offline
Old 10-05-2004 | 10:26 AM
Wobble's Avatar
SORE MEMBER
Are you using oil? an internal water leak will carry water out the breathers once the oil temp gets up to 212F. To check the rings, do a leak down test, any engine shop can do this. It will indicate condition of rings and valve seats. Running rich a lot causes excessive piston/ring wear.
Mark
Wobble is offline
