Oval port or rectangular port intake??? >
Old 10-18-2004 | 09:59 PM
  #61
Default Re: Oval port or rectangular port intake???
If you can rough the match porting in using a bridgeport and cone cutter it will save you many hours of grinding. Then just finish it with the hand grinder.
WETTE VETTE is offline
Old 10-19-2004 | 02:11 PM
  #62
Vinny P's Avatar
I hate the winter!!
I roughed in all the ports today. I may be finished by tomorrow. I'll post a picture when done.
Vinny P is offline
Old 10-19-2004 | 02:26 PM
  #63
cstraub69@comcast
. . .But transition is not and inch in. . . an intake runner to be effective needs gradual transistion to maintain port velocity. Random expansions in straight areas of the port are not good ideas.
Chris
Old 10-19-2004 | 04:00 PM
  #64
Vinny P's Avatar
I hate the winter!!
While I was working on the ports, I made what i believe to be a smooth transition. I had to go into the port a good 3" to achieve it.
Vinny P is offline
Old 10-19-2004 | 08:06 PM
  #65
robyw1's Avatar
Originally Posted by mcollinstn
I thnk I understand the step CStr was talking about where the intake runner leads into the head port. Roby was seeing the "brick wall" as an impediment to flow (which it is). But since it is on the bottom side, where fuel tries to fall out of the stream, the step "launches" the fuel back into the center of the stream where centerline flow rates re-atomize it. Kind of a trade-off: lose a fraction of total flow rate, gain better fuel atomization and burn-ability. At least that's how I see it.
My "eye" hates any mismatches anywhere. But I've watched flow numbers do really weird things with teeny changes that you'd swear would hurt it.
My eyes don't like mismatches either mcollinstn. Truth is we don't know what exactly happens to the fuel when it hits that obstacle. When you trip up the flow like that I see it as waves crashing over a seawall during a hurricane. In my opinion there will always be a wet spot there no matter the RPM. That not withstanding the biggest disruption of fuel atomization if the sudden opening of the throttle blades. All of the fuel that once was suspended is now on the floor of the intake trying to get pulled in every direction. With the injector atomizing fuel it is already in the port where velocity is high being rushed in ONE direction to the combustion chamber.
Roby
robyw1 is offline
Old 10-19-2004 | 09:31 PM
  #66
mcollinstn's Avatar
God bless injectors...
mcollinstn is offline
Old 10-20-2004 | 06:30 PM
  #67
Vinny P's Avatar
I hate the winter!!
I finished the manifold today. Thats as far in the runner as I can reach to smooth the transition. It feels real smooth, I hope it works.
Vinny P is offline
Old 01-25-2005 | 09:04 AM
  #68
p4-33's Avatar
Checkmate, as Paul Harvey used to say... let's hear The Rest of the Story.
How did your work end up on the dyno? What result did this intake work have on your torque curve? Do you have and before/after comparison numbers?
I've read this thread a couple of times and discussed the topic with my engine builder yesterday. There are some interesting ideas here, ones that I'm also trying to accomplish. Torque (long and flat) is my goal.
First, some background: I started with a pair of HP500's, and last winter I had the lower end freshened up,(now 509's) and added a set of Pro Action 320 aluminum heads with 119cc chambers. I stayed with 2mm dome pistons, so my CR is still right around 9:1, maybe slightly lower. We did some mild port work on the heads, they now flow 365 @.600 intake, and 255 @.600 exhaust. Running Ferea 2.25 intake and 1.88 exhaust valves. For the most part, the rest is stock HP500 (cams, carbs, Dart rect port intake). They currently dyno at 523hp @5250, and 562lbs @4500.
My focus for this winter is cams and carbs, and I'm trying to get my torque numbers to come in high under 4000, and stay flat as possible through 5500. I'm having custom cams ground, and the numbers aren't set yet, but ballpark is .600 lift on intake and .615 on exhaust, hydraulic roller lifters. I'll be going with a pair of Pro Systems 4150 carbs @950 cfm, with custom fuel curves based on flow numbers and cam data.
So now this thread is making me question what to do with my intake. My Dart rect port manifold is a decent piece, with good torque performance, and I could possibly benefit with the added runner length of a Brodix. But this oval port concept flared to match rect head ports has me intrigued.
Net, net, $350 or so x2 for the intakes, plus $200 or so x2 for port work puts me at $1200 for an end result that I haven't seen yet. If I gain 10-15lbs, it might not be worth the return on my investment, but if I'm looking at 30-40lbs, it's a different story.
Overall, I'm running a relatively small displacement motor (as compared to the Big Iron on this board), so port velocity of smaller intake runners might get me the torque numbers I'm looking for. In the end, I'd like to see peak torque around 625.
What's the scoop? I'd like to hear some "real world" data.
Thanks,
Brian
p4-33 is offline
Old 01-25-2005 | 06:17 PM
  #69
Vinny P's Avatar
I hate the winter!!
Brian,
I wish I could answer the question about rectangular port vs oval port with real data for both manifolds. But, I can't. I only dynoed the blended and port matched oval manifold.
I dug up this old thread I started with my dyno results. I hope it can help you answer a few questions.
http://www.offshoreonly.com/forums/s...540+dyno+today
Vinny P is offline
Old 01-25-2005 | 10:37 PM
  #70
p4-33's Avatar
Originally Posted by checkmate454mag
Here is the combination.
Dart Big "M" Block
Callies dragon slayer crank
Lunati Pro Mod rods 6.385"
JE Pistons 9.23 final compression
A.F.R. 315 cnc heads, Ferrea 2.25 intakes, 1.88 inconel exhaust
Dart single plane oval port intake, gasket matched to heads
Isky hydraulic roller
intake .578 lift--- 238* @ .050
exhaust .608 lift---248* @ .050
114* lobe seperation
Nickerson prepped 1050 dominator
Wilson tapered 1" spacer plate
Those are indeed some impressive dyno results.
Other than cubes, we're close on a number of things... yet even with the smaller oval port intake sizes, you're still feeding it with a 1050. Hmmm. And your cam numbers are smaller than I was thinking, but I'm leaving that equation up to Sterling. Good information, thanks.
So... can we attribute your torque numbers to velocity on the intake side? Did you do anything else out of the ordinary? Did you message the heads any more than the cnc work? I'm sure the work Nickerson did on your Dominators helped a lot.
Just trying to decide on whether to dive in to the intakes on my project.
Thanks again,
Brian
p4-33 is offline
