-   -   Identify This Carb??? (https://www.offshoreonly.com/forums/general-q/89036-identify-carb.html)
StrikinLightnin 10-20-2004 09:28 PM
Re: Identify This Carb???
Primaries=172
Secondaries=173
CMS Racing 10-20-2004 09:30 PM
from the looks of the original height of the choke horn and that it has 4 corner idle I would have to say it was a 850 with a list # 4781-4 or higher. it does not look like a 830 because of the boosters and the linkage.
cooltoys61 10-20-2004 10:34 PM
Hey, if you want to trash 'em, I'm a buyer.
Dixie Doug 10-21-2004 10:34 AM
1050-750 has those diameters
RumRunner 10-21-2004 12:06 PM
If it has 172 stamped on the primary butterflies, and 173 stamped on the secondary butterflies it is not a 4781 850. 850 carburetors have 1-3/4" Butterflies. 1-3/4" butterflies have 180 stamped on them. It is most likely a 750 carburetor. If you measure the center of the venturi with a pair of calipers around the booster I can tell you specifically.
robyw1 10-21-2004 12:15 PM
It is a Holley 750 Double Pumper 4779 that has aparently been outfitted with Annular boosters. It is not however not a marine carb.
Roby
StrikinLightnin 10-21-2004 12:25 PM
Roby
Why go with annular boosters?
robyw1 10-21-2004 12:56 PM
Originally Posted by sutphen30
do you have a pic of what your talking about.
thanks
Substack I use to use them and I really had to jet up. I felt an improvement but at the time I was only using a 650 CFM carb. This is much better than milling the choke shroud.
Roby
RumRunner 10-21-2004 02:31 PM
Roby
Roby,
Not sure what carburetor you're looking at, the pictures that were posted by strikinLightnin
robyw1 10-21-2004 03:01 PM
Yea those are what I was refering too. Was I mistaken about something?
Roby
