Transom Assy Rebuild Tools >
Old 10-21-2004 | 07:52 AM
Default Transom Assy Rebuild Tools
I am rebuilding an HP transom assembly over the winter and need the tools to pull the hinge pins, upper and lower pins, seals etc. Where is the best place to get these at a reasonable price, or can they be rented somewhere?
thanks
Shawn
shawn is offline
Old 10-21-2004 | 08:28 AM
Default Re: Transom Assy Rebuild Tools
About the only special tool you'll need is the 12 pinthinge pin remover. About $12 at any merc dealer.
Gary Anderson is offline
Old 10-21-2004 | 12:55 PM
Doller Offshore
i have the tool for the hinge pins,but a true hp gimbal ring does not have the the hinge pins--------954-237-0332-----------art
Old 10-21-2004 | 01:01 PM
Art, my T/As have the stainless steel at the hinge pin area and the book said the tool threaded into the stainless steel part and to use a slap hammer to remove it. These things need to pivot on something, if not a hinge pin, what is the correct name of the thingies on the side? How much is the tool to remove them?
thanks
Shawn
shawn is offline
Old 10-21-2004 | 02:05 PM
Doller Offshore
shawn,
they are hinge pins.i made a mistake,they both have a tool(hp vs, std) the hp hinge pins are held in w/ 2 or 4 screws and my mech says that a quick way to get them out is thread in a 7/16-14 bolt,grab w/ vise grips and tap and wiggle.it will come out. art
Old 10-21-2004 | 04:35 PM
Art, thanks
shawn is offline
HPJunkie
9
01-21-2007 04:55 PM
magnum
2
05-28-2006 05:59 PM
Biggus
04-23-2006 12:40 PM
Jerry B
0
07-27-2004 10:33 AM
Biggus
08-26-2002 08:10 PM
