Excalibur Hawk, good,bad?
#43
thanks fred,
it is all black with with custom airbrushed graphics and then clear coated twice. i will try and post a better picture tomorrow. there is enough room in the engine compartment for a conga line and blender drinks.
i also had 400 HP cyclones. i spoke with kamma and he was very helpful. i took his suggestions and am currently redoing the tops of the engines (still in the boat) and cams as i had a bad lobe and stuck valve.
the cam i chose is a comp. cams extreme 4X4 cam that makes tons of torque and good power to 5800 rpm's. they are ground 4* advanced already so i set it straight up. putting EMI thunders exhaust on as well. i rejetted the edelbrock 750's to 4% richer, may try 8% though. am turning 15X19's currently and it ran about 55mph before. the engines are close to 500HP each now as opposed to a real world 370 with stock crappy log exhaust. i will let you know what i picked up in speed. may 17'th the tractor trailer comes for it. i would like to find some 20" or 21" TRS cleavers to try but they have been hard to find.
i have two engine installation manuals, if you need one let me know and i'll mail it to ya. Fran
#44
excaleagle42 - You want to try 15x21 overhub cleavers or thru-hub? Have both setting on the shelf. On my boat the overhubs were terrible getting on plane. If you want to try either set just pay the shipping and I'll send them. If you decide to keep them you can send me what ever you think they are worth (think cheap
-Greg
ps- use [email protected] for e-mail, I think the auto-forward from my registered e-mail has died.
).-Greg
#46
Fran, I would like to see a better pic of that Eagle....its got to be beautiful with all the black, see if you can get a bigger pic posted of it. What does the engine installation manuels have in them? I have a manuel on the trs drives but thats it, let me know, Thanks Fred
#47
Fred i couldn't post a better pic because of the limit on size. i will e-mail one directly if you want.
the manual tells you how the x dimension was figured, wiring diagrams, and lube specs. it is pretty good stuff. Fran
#48
#49
Fred,
I didn't forget about you...The engine builder at Falcon wasn't around 2 weeks ago and I didn't make it over there this past weekend...I will be over there this coming weekend, so I'll ask about the refer and speeds, etc.
Sean
Sean
Fran
