Engine Mounts?
Has any one used billet engine mounts like below? Is there a specific horsepower rating on them? I am trying to determine whether to use these or the standard merc mounts with the rubber bushing. Should there be concern with either mount in the 550-600hp range?
http://www.trickmarine.net/images/pr...ages/ACF7A.jpg |
Re: Engine Mounts?
I have the mounts in my boat and are very happy with them. If they are setting on some aluminum angles, they are not as strong as a offshore mount. They are much better looking than the stock mount though.
Re: Engine Mounts?
I have the mounts you pictured,they work good,haven't broke yet,i bought them from dana and also got there big aluminum l angles to replace the stock ones. i had 3 seasons of use with the stock mounts before switching,they never broke even with 502 procharged but i was worried they would,Smitty
Re: Engine Mounts?
Do they have any kind of locking tabs on them? What keeps them from moving up or down?
Re: Engine Mounts?
ccarloss-
Those are good looking mounts, What is the brand and where is the best place to find them? I need to replace and those mounts look like the ticket. Thanks!! |
Re: Engine Mounts?
I got mine from Eddie Marine. He was the first to carry them. You could try with Fred on the board. His company is "Trick Marine". If he doesn't have them, tell him that Cord says he needs to GET WITH THE FREEKIN' PROGRAM! :D
Re: Engine Mounts?
I bought mine from dana products,i added 2 more nuts on each one and double nutted them above and below the bracket on motor. i also sanded the smooth finish off the bottom side because i was afraid they would walk around on stringer angles,Smitty
Re: Engine Mounts?
Perfectmix, the picture is from Fred's site Trick Marine. He carries them. http://www.trickmarine.net/
Re: Engine Mounts?
Thanks guys for the lead. I will give trick marine a call
josh |
| All times are GMT -5. The time now is 06:13 AM. |
