525sc's Rebuild >
525sc's Rebuild
525sc's Rebuild
Old 11-12-2004 | 06:36 AM
iamfaster's Avatar
Smile Re: 525sc's Rebuild
thanks for the info....any body else ? Gotta keep this post at the top
iamfaster is offline
Old 11-12-2004 | 06:37 AM
iamfaster's Avatar
Default Re: 525sc's Rebuild
Greencard, what heads on your set-up.
Old 11-12-2004 | 07:02 AM
CFD12's Avatar
I am the "friend" Greencard is talking about I can Email you the cam specs and possibly the dyno sheets if you give me your address. My heads are stock GM square port. Gil exhaust 1050 dominator B&M 174.
CFD12 is offline
Old 11-12-2004 | 02:41 PM
Why can't you do innercoolers???
The whipple coolers are pricey but only add an inch or less in height. Upping the boost, and adding a cooler, and changing the cam should get you to 600hp.
Griff is offline
Old 11-12-2004 | 06:35 PM
iamfaster's Avatar
dont want to cut into the hatch, not even with the kit that fis into the sunpad foam. Flame arrestors r about 1/2" below. Also, want to rebuild motors completely to keep for next 2-3 yrs. Only so much $$$$ to spend
Old 11-12-2004 | 06:48 PM
iamfaster's Avatar
cfd12... my e-mail address : [email protected]
thanks
Old 11-12-2004 | 07:16 PM
lucky strike's Avatar
I rebuilt my 525 Hawk Blower motors-- used all the same components as the stock
engines had, they had 405 hrs. on them. ran 4900 at 72 mph.Everything is new but the block 30 over 468 cu----- now 5300 at 76 mph. with 25 inch props.
Put a set of 27's on an went back to 5000 rpm's at 76 mph I can give you the name of my engine builder if you want + he gave me a 1 year guarantee. So far so good Have 43 hrs. an I'm thrilled ! They are in a 38 Top Gun--Carbon Fiber Boat.
Lucky Strike
lucky strike is offline
Old 11-12-2004 | 07:58 PM
iamfaster's Avatar
Lucky Strike, did they do any head porting or valve work .
Old 11-13-2004 | 10:11 AM
iamfaster's Avatar
bringing back to top..............
Old 11-13-2004 | 10:18 AM
mcollinstn's Avatar
You say Dart cast iron heads. I assume you already have a deal found for these?
You are on "a budget", too? The small blower is NOT your friend in this endeavor. You will need to keep boost pressure low, to combat heat, but you can spin it as fast as you need to in order to keep 4-5 psi. In other words, with good flowing heads and a matched cam, you can make your hp goal with no trouble with the little blower, but it would be easier AND CHEAPER to get there with a larger huffer and more boost.
mcollinstn is offline
