1998 502 Efi >
1998 502 Efi
1998 502 Efi
Old 11-11-2004 | 09:35 AM
Dean Ferry's Avatar
Default 1998 502 Efi
Are 1998 502 EFIs gen. V or gen. VI blocks? What is the diff between the 2?
Thx,
MD
Dean Ferry is offline
Old 11-11-2004 | 10:18 AM
Dave M's Avatar
Veteran: Navy
Default Re: 1998 502 Efi
I know they are Gen VI, but I can't tell you what the differences are.
Dave M is offline
Old 11-11-2004 | 10:20 AM
A 1998 is a Gen VI. The big difference is the roller cam/lifter setup. The lifter bores are taller with a guide to keep the roller lifters from turning, Gen VI also has a cast aluminium timing chain cover with six bolts instead of ten. The harmonic balancer also is marked in degrees. Another big change is that the Gen VI can accept Mark IV big block heads supposedly and the Gen V could not due to the size of the water passages. Also Gen V & VI have a one piece rear main seal vs a two piece in the Mark/Gen IV. Also the water flow and internal oil flow pattern changed some in the Gen V & VI vs the Gen IV.The mechanical fuel pump option is also gone in Gen V & VI block vs Gen IV.
Pismo10 is offline
Old 11-11-2004 | 11:14 AM
Dean Ferry's Avatar
Pismo10,
Thanks for the input.
Dean
Old 11-12-2004 | 08:45 AM
Dean Ferry's Avatar
Are there any valve springs,annual Impeller change out or periodic maintnance related items I should worry about other than the Ex. Manifolds, annual Impeller change out, ?
Thx,
Dean
Old 11-23-2004 | 01:17 PM
Dean Ferry's Avatar
ttt
Old 11-23-2004 | 10:50 PM
mcollinstn's Avatar
502 EFI ?
You mean 502 MPI?
or
a blue 500EFI?
blue motors need more attention to springs and lifters.
black motors only need gasoline and an occasional oil change. pretty much forever.
mcollinstn is offline
Old 11-24-2004 | 05:46 AM
Dean Ferry's Avatar
mcollinstn,
502 MPI is what I meant.
Thanks,
Dean
Nitrousworx
11
04-25-2008 09:38 PM
Maritime_Eng
2
07-07-2006 09:13 PM
WRedmann
1
11-28-2005 11:21 AM
26sonic
1
10-20-2003 07:46 AM
26sonic
8
04-22-2003 07:39 PM
