Fountain 42
Old 11-16-2004 | 09:53 PM
Cool Fountain 42
I just got a Fountain 42 with 525's and Bravo XR's and have a couple of questions for you all...
Mine throws a big rooster tail at any speed between 40 and 70, even with minimal trim. It levels out between 70 and 80. In past boats I've had, I had to trim up pretty hard to throw a substantial tail... more for show than go! It's not a problem for me so long as I'm not wasting power. Is this normal for my rig?
The boat came with Bravo I 32 pitch props. Has anyone found a better prop to peak the top speed a little bit? Will lab finishing help?
Thanks - hope to join you all on some runs in Florida.
Jnewton is offline
Old 11-17-2004 | 06:34 AM
Talking Re: Fountain 42
Call Julie at Throttle Up in Florida she will be able to help you. They put more speed in my boat with there tweaked props.
Badtoon is offline
Old 11-17-2004 | 07:19 AM
mcollinstn's Avatar
Default Re: Fountain 42
Most of your "tail" is due to a higher prop height than your other boats. The top of the blades come out of the water and the tail results. Normal.
mcollinstn is offline
Old 11-17-2004 | 08:27 PM
monsta
What year is your boat, pending that , comes into play the step configuration and x dimension as far as why your tail is so high. 32 sounds a little steep of pitch, especially for 525's. What's your gear ratio? Also you may want to try a set of herring's or maximus's from mercury. Hrydromotive's new 5 blader is also a decent wheel. Lastly what is your speed, for ratio , x dimension, and mph will help you determine if this tail is a good thing or a sign of something else.
Old 11-17-2004 | 08:47 PM
Definitely have your props labbed. When I did mine I was suprised at how much smoother the boat ran. I lost a little hole shot but ran 88mph with half tanks, myself and wife on board in 1-2' chop. (lake michigan)
I had George Helsop do the props out of Chicago, it took three times to get it right but it was worth it.
2005 42 Executioner 525's
kageman is offline
Old 11-17-2004 | 09:52 PM
Thanks for the great replies... all of you. The boat is a 2005 Lightning. I have run it up to only 79mph so far, but always had 5 people and lots of gas. I want to give the engines a few hours before holding it at top end too long. She's only been out twice so far. I think it was about 5300 or 5400 rpm at the time. I'll get back to you with the rest of the info.
If I was going to lab the props, can I supply them to Throttle-Up? Or do I have to buy them from them? Any idea on cost?
Thanks Again!
Jnewton is offline
Old 11-18-2004 | 06:33 AM
I'm just used to having to trim pretty high to throw the tail. Usually we do that to show off more than to peak the speed. This rig throws the major tail when the trim guage is still on 1.
Jnewton is offline
Re: Fountain 42
Call Julie 877 842 6855 Toll Free She will be able to tell you what they can do for you.
Badtoon is offline
Old 11-18-2004 | 06:58 AM
Cool Re: Fountain 42
I hear ya, but let's hope that Fountain knew what they were doing when they calculated the "x" dimension, prop height and all that. I'm sure Reggie did this one personally!
How do I find the ratio of my drives? Is it marked on the drives anywhere?
Jnewton is offline
Old 11-18-2004 | 09:18 AM
Thanks... I'll go over there tomorrow if I get a chance.
Jnewton is offline
