Cam Help on 502 >
Cam Help on 502
Cam Help on 502
Old 11-19-2004 | 08:59 AM
Leathl_WS6's Avatar
Default Re: Cam Help on 502
Originally Posted by KAAMA
Leathl,
Reed Cams makes a hydraulic roller 232*/238* @.050" lift (284*/290* advertised) .578"/.578" lift all on 112* lobes. In fact I have a pair of these cams right now and they have NOT been used and are made for a Mark-4 block. I paid about $250 each for these cams. I will sell them to you for $230 each if you like. Otherwise, I believe at least one good person to consult would be "rmbuilder" aka Bob Madara concerning cam selection.
Thanks Kamma but I'm not going to upgrading the whole valve train to roller. Would cost to much for gains I could not use.
Rob
Leathl_WS6 is offline
Old 11-19-2004 | 09:02 AM
Leathl_WS6's Avatar
Originally Posted by sutphen30
i just saw this,go edelbrock rpm,,you'll have cheap hydro lifter set up,around 550hp,more than enough to break the drives,,,and they sound awesome.just prop for around 5800-6000rpm max. less prop and more rpm will keep the trs alive,for a little longer.
Thanks for the vote of confidence on my drives... Hopefully I can baby them a bit and make them last for a season or 2. Is more rpm really the ticket?
Rob
Old 11-19-2004 | 04:12 PM
WAGS382's Avatar
Go roller, it is cheaper in the long run. If you go flat tappet you will be replacing them soon.
WAGS382 is offline
Old 11-19-2004 | 10:22 PM
Leathl_WS6's Avatar
Wags why do think I would have to replace them? just curious..
Rob
brent05
04-23-2006 10:05 PM
brent05
0
04-16-2006 06:08 PM
brent05
1
04-15-2006 07:04 PM
migara422
19
05-26-2005 12:39 PM
migara422
9
05-17-2004 11:54 AM
