compression, PSI >
compression, PSI
compression, PSI
Old 11-21-2004 | 05:15 PM
Default compression, PSI
What should/would the compression of a 330 hp BB Chev be, with factory flat tops, std bore and Vortec L29 heads if everything was new? 160 psi or more? Has anyone cc'd these chambers, they look small maybe 105cc? Thanx, Andy...
Andy is offline
Old 11-21-2004 | 09:45 PM
mcollinstn's Avatar
Default Re: compression, PSI
Older 330's were more like 125 psi.
mcollinstn is offline
Old 11-21-2004 | 11:10 PM
They are small.I had a 454 that cold cranked at 180 psi.with a 224/230 cam installed at 106 atdc.Be carful with these heads on a carb motor as they will detonate really easy.Use about 28* total timming.As you bring the commpresion ratio up don't be conservative with the cam or you can get into a high cylinder pressure situation.These heads on trucks use a computer managment system to cool things down fast when detonation occurs.
HARRISONMIRAGE is offline
Old 11-22-2004 | 12:28 AM
mopower's Avatar
Toxic FORMULA
I have a pair of 1989's with 700 hrs. that still pump 150 psi.
mopower is offline
Old 11-22-2004 | 03:53 AM
offthefront's Avatar
700 hours ...hmmm...would love to make it to 25 hours ...
offthefront is offline
Old 11-22-2004 | 05:48 AM
mopower's Avatar
Toxic FORMULA
Too many places "think" they're engine builders
mopower is offline
fantastixvoyage
12
06-19-2007 06:09 AM
custom29scarab
4
08-08-2005 02:47 PM
BOATING ON A BUDGET
4
02-14-2005 09:31 PM
FlyFast
2
09-07-2003 10:07 AM
Mad Hatter
08-10-2003 11:55 PM
